'73 Charger light problem #613089
02/14/10 11:17 AM
02/14/10 11:17 AM
Orange Park, FL
MRHWS Offline OP
MRHWS  Offline OP
Orange Park, FL
I recently purchased a '73 Charger and had the bad steering box replaced. Car also had a tiny 13" wheel and had replaced with a repo 15" tuff wheel. Also had no left turn signal. Right worked fine as did the flashers. Now, no signals, no flashers and more importantly, no brake lights. Is the steering assembly harness bad and would that affect the brake lights?
1973 Charger SE 1974 Charger Rallye 440 Aztec 2008 Charger SRT8
Re: '73 Charger light problem [Re: MRHWS] #613090
02/14/10 11:53 AM
02/14/10 11:53 AM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
I hate tracking these problems down. Years ago, a similar problem in my '74 Satellite traced to a shorted trunk light wire.
Re: '73 Charger light problem [Re: MRHWS] #613091
02/14/10 12:22 PM
02/14/10 12:22 PM
New Mexico, USA
attaboy Offline
attaboy  Offline
New Mexico, USA
Replace the turn signal switch assembly. All those functions you're having trouble with go through that. Get a good quality Mopar one, not a cheap replacement from the local auto parts store.
attaboy
Re: '73 Charger light problem [Re: attaboy] #613092
02/14/10 02:04 PM
02/14/10 02:04 PM
Orange Park, FL
MRHWS Offline OP
MRHWS  Offline OP
Orange Park, FL
Thanks, I'll go this route.
Re: '73 Charger light problem [Re: MRHWS] #613093
02/14/10 03:05 PM
02/14/10 03:05 PM
If you want to diagnose it www.mymopar.com has wiring diagrams for the colors to work on and a parts store circuit tester, the one w the alligator clip on one end of a wire and a light w a thin metal pointer on the other end is the one to use & is only several bucks. I'd check for fire on the particular color wires in the pull apart electrical connector(not the one for the ign but the one for the turn signals/brake lights) keeping both halves still connected & see what you find for opens. If you do purchase a TS harness ahead of time I'd plug it in the connector outside of the column before undoing the steering wheel.
