8 1/4" limited slip interchange?? #612821
02/13/10 10:41 PM
02/13/10 10:41 PM
Spring Grove, PA, US
Mr.Mopar Offline OP
Mr.Mopar  Offline OP
i have a 8 1/4 limited slip for sale and i had several guys ask if it would fit there cars..
so, this came out of a 98 dakota and has an ABS "sensor gear?" on it and the old ones dont.. so would this fit a 70's 8 1/4 rear?? are the splines different??
Thanks, Kevin
1996 cummins diesel ext cab, long bed
1966 Valiant 4dr(318- 3.55gears, 13.31@ 102mph),
1974 Duster(360- 13.63@ 99.96 w/3.23 gears),
1933 Dodge DP (201)
Re: 8 1/4" limited slip interchange?? [Re: Mr.Mopar] #612822
02/13/10 10:43 PM
02/13/10 10:43 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
1969-96 are 27 spline
1997 and newer are 29 spline.
It will fit in an older rear end but you'd need to run 29 spline axles, probably custom length too.
