Timing chain tolerance? #612803
02/13/10 10:38 PM
02/13/10 10:38 PM
northeast texas
strokin73cuda Offline OP
northeast texas
I have a rollmaster set from my previous build not many miles. It has .530 slop in the chain (side to side)on the current block. I don't know what it had before It was built by someone else, is this acceptable?
496 stroker,Indy srs , new best 6.87 @ 98 1.46 60'
Re: Timing chain tolerance? [Re: strokin73cuda] #612804
02/14/10 01:17 AM
02/14/10 01:17 AM
IL
knyech1 Offline
knyech1  Offline
IL
I just talked to a dealership a couple weeks ago about my friends 4.3L in his Blazer that I was rebuilding and he said .5in is too much. I have a timing chain tensioner in mine with a billet timing set, that would tighten it up
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: Timing chain tolerance? [Re: strokin73cuda] #612805
02/14/10 09:40 AM
02/14/10 09:40 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The tighter the better... you would get less cam
fluctuation... a tensioner would help alot.... I
never tried to figure out the degrees of fluctuation
per .1 of slop.... I use a gear drive so I can really
tell you what to do
Re: Timing chain tolerance? [Re: MR_P_BODY] #612806
02/14/10 09:53 AM
02/14/10 09:53 AM
IN
ahy Offline
ahy  Offline
IN
Agree the less the better. It may be time for a .005" shorter chain. On my engine (line bored) I had to go with a .010" shorter Cloyes to get it tight.
Re: Timing chain tolerance? [Re: strokin73cuda] #612807
02/14/10 10:21 AM
02/14/10 10:21 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
is that measurement with all the slack on 1 side of the chain?
what is the use of the engine,valve spring psi?
myself i would replace it with that much slack but i use a roller cam with stiff valve springs.
i last checked my timing and with 1/4" slack i had i think less than 1* of play with a large timing wheel on the crank.
Re: Timing chain tolerance? [Re: blownzoom440] #612808
02/14/10 10:36 AM
02/14/10 10:36 AM
northeast texas
northeast texas
That is with all the slack on one side. It is an SR headed rb stroker with solid roller setup so the springs will be pretty stiff Dwayne is still working on the heads so I don't know yet exactly how stiff. Thanks I will go ahead and order another timing set. I also have a summit wheel I will check and see what the degrees of slack shows just for kicks and post them here.
Re: Timing chain tolerance? [Re: blownzoom440] #612809
02/14/10 10:38 AM
02/14/10 10:38 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
i had close to this much slop with a brand new chain. i used my old one that had less slop
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: Timing chain tolerance? [Re: blownzoom440] #612810
02/14/10 11:18 AM
02/14/10 11:18 AM
northeast texas
northeast texas
Heres some pics it shows 1.5 degrees total chain slack. What would be acceptable?
Re: Timing chain tolerance? [Re: strokin73cuda] #612811
02/14/10 11:19 AM
02/14/10 11:19 AM
northeast texas
northeast texas
the other way.
Re: Timing chain tolerance? [Re: strokin73cuda] #612812
02/14/10 12:06 PM
02/14/10 12:06 PM
ELYRIA,OH
ELYRIA,OH
certainly not in a race engine.
what did the chain measure in slack?
Re: Timing chain tolerance? [Re: blownzoom440] #612813
02/14/10 01:24 PM
02/14/10 01:24 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
MrPBody, Would all of us be better to use a gear drive in a all out race-engine? I would like a belt drive but that is out of my price range.
I'm also trying to make my mind up if I will reuse my timing(roll master)chain again.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Timing chain tolerance? [Re: blownzoom440] #612814
02/14/10 10:01 PM
02/14/10 10:01 PM
northeast texas
northeast texas
When measuring the chain with all slack on one side it will move a total of .530 left to right. And should I be running a gear drive? I would have thought a good gear and chain to be sufficient.
Re: Timing chain tolerance? [Re: strokin73cuda] #612815
02/14/10 10:18 PM
02/14/10 10:18 PM
ELYRIA,OH
ELYRIA,OH
how many gear/chains can you get for the cost of a gear drive?
there is more to it than that buti wanted to .
Re: Timing chain tolerance? [Re: blownzoom440] #612816
02/14/10 11:46 PM
02/14/10 11:46 PM
northeast texas
northeast texas
At least 4 including shipping for some good ones, but your'e right thats not all there is to it but if thats what I need or should be getting then I will. I just really thought they were for blower motors or something really highend. I don't know anything about who has a good geardrive or scince my motor has been correctly linebored now do I need to measure the distance from the crank to the cam centerline?
Re: Timing chain tolerance? [Re: strokin73cuda] #612817
02/15/10 12:02 AM
02/15/10 12:02 AM
ELYRIA,OH
ELYRIA,OH
there is a lot of people with roller cams that have chains still.i have only had a roller for a yr so time will tell for me.
Re: Timing chain tolerance? [Re: strokin73cuda] #612818
02/15/10 01:07 AM
02/15/10 01:07 AM
Off the Rollmaster and buy a good Cloyes brand billet set with the needle bearing thrust washer set up I have one on my street stroker with a Comp Cams solid roller with 650 lbs open, that motor and chain set has close to 1200 street miles and lots of laps at the drags with 7000+ rpm shifts, it had less slop than your does the last time I had the motor apart(it broke a lifter wheel in half
Re: Timing chain tolerance? [Re: strokin73cuda] #612819
02/16/10 11:33 PM
02/16/10 11:33 PM
IN
ahy Offline
ahy  Offline
IN
On measuring... the shop I was working with on my line bored "B" engine didn't have a way to measure so it was trial and error. The stock spec Cloyes was way loose, the .005" shorter was better but still a little sloppy and the .010" shorter Cloyes was tight and just right. I was able to return the chains that didn't work so I lost only time with the trial and error.
Re: Timing chain tolerance? [Re: ahy] #612820
02/17/10 01:16 AM
02/17/10 01:16 AM
northeast texas
northeast texas
Did you try using the 5.152 center that the venders use for a center or just go for it by trial and error? I havn't ordered a set yet and I have some time but I would like to get it right the first time. Thanks
