833 o/d 4 speed trans. #612453
02/13/10 03:20 PM
02/13/10 03:20 PM
north carolina usa
gretsch Offline OP
gretsch  Offline OP
north carolina usa
will the 833 o/d 4 speed trans fit 70 models bellhousings, o/d has 4 3/4'' bearing retainer size, while a cast iron 833 4 speed has a 4'' bearing retainer. pm me with any helpful answers.
Re: 833 o/d 4 speed trans. [Re: gretsch] #612454
02/13/10 08:58 PM
02/13/10 08:58 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
There are 3 sizes if I remember right.
4.35 for small blocks
4.80 for big blocks
5.125 for OD
You'll have to swap the retainer if that's possible, or hog out the bellhousing hole to fit.
Re: 833 o/d 4 speed trans. [Re: 440newport] #612455
02/13/10 10:34 PM
02/13/10 10:34 PM
Rome, Ga
sbhpcb Offline
sbhpcb  Offline
Rome, Ga
I had to turn the bearing retainer down and mill out the center hole on the bell.
Re: 833 o/d 4 speed trans. [Re: sbhpcb] #612456
02/13/10 11:44 PM
02/13/10 11:44 PM
Southern Indiana
75RoadRunner Offline
Southern Indiana
The retainer will not turn down small enough because the bolt holes will not allow it. The bell housing can not be milled out enough because of the throw out bearing clip. I had to remove from both to make it work, but it sure is nice when those rpm's drop on the high way. The only draw back is the big gap between 2nd and 3rd gears.
Re: 833 o/d 4 speed trans. [Re: 75RoadRunner] #612457
02/14/10 01:36 AM
02/14/10 01:36 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I thought you could swap on a smaller bearing retainer?
Re: 833 o/d 4 speed trans. [Re: DaytonaTurbo] #612458
02/14/10 01:58 AM
02/14/10 01:58 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
As far as I know, the simplest solution is to get the bell housing from a 318/OD truck ('81 to '87).
Mo' Farts
Moderated by "tbagger".
Re: 833 o/d 4 speed trans. [Re: Grizzly] #612459
02/14/10 09:01 AM
02/14/10 09:01 AM
Rome, Ga
sbhpcb Offline
sbhpcb  Offline
Rome, Ga
I bought 1 on ebay. it was suppost to be a 71 to 74, but they lied. There is always some on ebay new, they say they are regular bells but look closely at the holes for the fork bracket as they are different along with the hole for the bearing retainer. You will need the fork bracket and I do not know if the fork will interchange. This is most likely cheaper than the machine work on the bell you have now. I might buy your old bell, PM me. Look at ebay Item 370316356429 I think this is what you need.
Re: 833 o/d 4 speed trans. [Re: 75RoadRunner] #612460
02/16/10 02:46 PM
02/16/10 02:46 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Wrong.
I turned mine down in less than 5 minutes. The bolt pattern on the OD and the non-OD large bearing is the same.
I put my 833 OD in the bellhousing I used with my 18 spline 833.
There is a big jump in the gears.
- Stu Harmon
Re: 833 o/d 4 speed trans. [Re: feets] #612461
02/16/10 03:33 PM
02/16/10 03:33 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
I've turned the retainer a dozen times...it works just fine.
Don't ruin a good bellhousing!! If you need to switch back simply make a sleeve for the retainer to bring it back to size.
Re: 833 o/d 4 speed trans. [Re: gretsch] #612462
02/16/10 07:16 PM
02/16/10 07:16 PM
Central Ohio
Ledman_70 Offline
Ledman_70  Offline
Central Ohio
How did you guys turn your retainers down... are you machinists? Did you do it at home? Thanks
Jeff Adams 64 426 Polara
Re: 833 o/d 4 speed trans. [Re: Ledman_70] #612463
02/16/10 09:03 PM
02/16/10 09:03 PM
Rome, Ga
sbhpcb Offline
sbhpcb  Offline
Rome, Ga
I think there may be 2 different bolt patterns on the front retainers seems there maybe 2 different front bearings as well?
