55 Chrysler Windsor disc brake conversion #61225
05/21/08 06:58 PM
05/21/08 06:58 PM
Tennessee
classof65 Offline OP
Tennessee
H E L P Is there any information out there about converting an old sled like this 55 Chrysler Windsor to disc brakes? What parts can be used and has anyone tried this before. The car has a current 383 and aluminum 727 in it, updated drive shaft and rear axle, but it takes FOREVER to stop and you have to have legs like King Kong to bring it down even from reasonable speeds.
Let me know. You can E mail me if you wish at Racewthrev@aol.com
Re: 55 Chrysler Windsor disc brake conversion [Re: classof65] #61226
05/21/08 07:10 PM
05/21/08 07:10 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
Have you checked scarebird.com?
Re: 55 Chrysler Windsor disc brake conversion [Re: FuryUs] #61227
05/21/08 07:36 PM
05/21/08 07:36 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
Here is the place for you.
Disc Brakes
Re: 55 Chrysler Windsor disc brake conversion [Re: HemiStan] #61228
05/21/08 08:51 PM
05/21/08 08:51 PM
Tomorrow.
Damned67 Offline
Damned67  Offline
Tomorrow.
Disc Brakes
I had a '56 Belvedere as my first Mopar and my first V8. I'd give almost anything to have that car back again.
Re: 55 Chrysler Windsor disc brake conversion [Re: Damned67] #61229
05/23/08 06:00 PM
05/23/08 06:00 PM
Tennessee
Tennessee
thanks for the input. Doesn't look like to bad a swap.
Rev.
Re: 55 Chrysler Windsor disc brake conversion [Re: classof65] #61230
05/23/08 08:02 PM
05/23/08 08:02 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Maybe a 76-80 F body front end?
sold a complete set-up to a guy who put it under a 52 Cranbrook. He got the K frame with motor mounts mounting bolts and iso blocks, power disc brakes(complete)with master booster prop valve and brake pedal, power steering box pump and lines, adjustable suspension and a sway bar in a 4 bolt package for under $300. I threw in the steering column with keys Seemed pretty happy to me when he called me after installing it!
