68 B body number stampings #611340
02/12/10 11:47 AM
02/12/10 11:47 AM
KS
68SportSatvert Offline OP
KS
On a 68 B body are there any numbers besides the VIN stamped on the body??
Thanks!!
Re: 68 B body number stampings [Re: 68SportSatvert] #611341
02/12/10 12:33 PM
02/12/10 12:33 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
In 68 the VIN isn't stamped in the body. 69 and up only.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 68 B body number stampings [Re: DPelletier] #611342
02/12/10 03:42 PM
02/12/10 03:42 PM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
Typically you would find the last 8 digits of the VIN on top or the trans bellhousing and engine flange around 12 O'clock position. These shown are a non matching pair.
Re: 68 B body number stampings [Re: 70mopes] #611343
02/12/10 08:04 PM
02/12/10 08:04 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Only the auto's have it stamped there, manual tranny's are stamped on the pad as 69 and later
Re: 68 B body number stampings [Re: rrunner] #611344
02/12/10 09:15 PM
02/12/10 09:15 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
i don't beleive 68 had the vin stamped on the motor or tranny.69 and newer. 68 has the numbers stamped on upper core support and under trunk weatherstrip on drivers side. I beleive it will be the order number not the vin. It should match the order number on the fender tag.
Re: 68 B body number stampings [Re: Dougsmopars] #611345
02/12/10 09:45 PM
02/12/10 09:45 PM
KY USA
mopargem Online tonguue
mopargem  Online Tonguue
KY USA
Correct the VON is stamped on the body but the VIN is definitly stamped on the top of engine by the bellhousing in later 68 cars. My old 68 Charger R/T 440 was stamped there, kind of more to the drivers side around 1 or 2 oclock.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: 68 B body number stampings [Re: mopargem] #611346
02/12/10 10:14 PM
02/12/10 10:14 PM
Dougsmopars Offline
Dougsmopars  Offline
Learned something new. I looked at the top on my 68 no numbers stamped up there. Casting date 11-23-67 build date 01-02-68. I'll look good again tomorrow maybe i just didn't notice it. I know 69 and up it's stamped on rail at oil pan.
Re: 68 B body number stampings [Re: mopargem] #611347
02/12/10 10:34 PM
02/12/10 10:34 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
What do you mean by later? My Dec. R.R. engine and auto trans were stamped, my Feb R.R. parts car engine and auto trans were stamped and my May R.R. engine and man. trans were stamped.
All of these cars are St Louis by the way
Re: 68 B body number stampings [Re: rrunner] #611348
02/12/10 10:40 PM
02/12/10 10:40 PM
KS
KS
Thanks guys!!! So, to make sure I have this correct, the VIN is NOT on the body stamping but the sequence number is? Is the VON the same as what's referred to as the sequence number? As for the VIN on the engine/trans I've seen it there on late 68s but no on the early ones.
Re: 68 B body number stampings [Re: rrunner] #611349
02/12/10 10:46 PM
02/12/10 10:46 PM
KY USA
KY USA
My 68 Charger was built after Jan 68, cant remember off top of my head, way to may cars ago. I may have the info somewhere, now I wish I kept better records of past cars like data tags, sheets, engine numbers and all. At the time I had heard that early 68 cars didnt have the VIN stamped on drivetrain. Dont know at what point they started doing this, plant, or if its even true that early cars werent stamped, but by evidence of Dougs car, I would say some early cars arnt stamped.
Re: 68 B body number stampings [Re: 68SportSatvert] #611350
02/12/10 10:48 PM
02/12/10 10:48 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
The SO (shipping order),or as some say VON, number is found on the rad support and under the left side trunk weather strip. The only other place it's found is on the fender tag and build sheet. No vin # stamped on the body anywhere in 68.
Re: 68 B body number stampings [Re: rrunner] #611351
02/12/10 10:49 PM
02/12/10 10:49 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The law required VIN stampings on the engine and trans begining 1/1/68 but the managment was trying to get the program working & in place ahead of schedule to be in compliance... So most Dec cars probably are stamped but it could vary from day shift to night shift or if the guy that was trained to stamp VINs called in sick his replacement might miss a few.. Fact is that really happened through out the year...
Re: 68 B body number stampings [Re: 1_WILD_RT] #611352
02/12/10 10:53 PM
02/12/10 10:53 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
OK, I knew it came about in 68 but didn't know when it was required by.
Re: 68 B body number stampings [Re: rrunner] #611353
02/13/10 10:13 AM
02/13/10 10:13 AM
KS
KS
Thanks again!!! That is the EXACT information I was looking for!!!
Re: 68 B body number stampings [Re: rrunner] #611354
02/13/10 03:37 PM
02/13/10 03:37 PM
Dougsmopars Offline
Dougsmopars  Offline
Checked mine again today. NO numbers stamped on top of block or transmission.
Re: 68 B body number stampings [Re: 68SportSatvert] #611355
02/15/10 04:47 PM
02/15/10 04:47 PM
DPelletier Offline
DPelletier  Offline
Just for clarity, the VON (vehicle order number) which is stamped into the rad support and quarter trunk rail on '68 B bodies isn't the same as the sequence number. Most times when people refer to "sequence number" they mean sequencial VIN which is the 6 digit number at the end of the VIN, although Lynch Rd. fender tags also have a "gate sequence" number at the top which seems to mean very little to anybody.
As stated earlier, only the fender tag or broadcast sheet ties the VIN# to the VON#
Re: 68 B body number stampings [Re: DPelletier] #611356
02/15/10 05:34 PM
02/15/10 05:34 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
1968
VON# = Stamped into the Fender tag, uppers drivers quarter under trunk weather stripping, top of drivers radiator core support. Printed on the Broadcast Sheet
Full VIN# = Stamped into the dash VIN Tag, printed on the Broadcast Sheet, and possibly on other factory or dealer paperwork
VIN Sequence Number (last 6 digits of the VIN#) stamped into the engine and transmission. In 1968 the engine stamping was typically stamped on the top of the bell housing flange as shown in pics above, I have heard reports of 68's with the number stamped onto the raised pad on the lower passenger side just above the oil pan rail but have never seen one myself. Transmission stampings were as shown on automatics,just behind the engine stamping on the upper bell housing, 4 speeds were stamped into the raised pad on the passenger side (pic attached). Concerning those who claim to have original cars that were never stamped, yes it's possible, but I have never seen any original examples, if any of you have pics of those areas left blank by the factory please e-mail them to me if you don't mind, along with any other replated photos of the engine or trans numbers.
Re: 68 B body number stampings [Re: mopargem] #611357
02/15/10 07:11 PM
02/15/10 07:11 PM
Dougsmopars Offline
Dougsmopars  Offline
checked mine today. Jan 02 68 build date. No vin stamped on back of motor or bell houseing. Engine cast date 11-23-67
Re: 68 B body number stampings [Re: Dougsmopars] #611358
02/15/10 10:46 PM
02/15/10 10:46 PM
Slantytown
DUFFMAN Offline
Ask And Ye Shall Receive
DUFFMAN  Offline
Slantytown
My 1968 Sport Satellite is a Lynch Road car. The engine is stamped on the bell, but they only got the last 3 digits of the sequence number deep enough to read.
Just to be clear, the fender tag in 1968 does not have the VIN on it, only the VON, and the body stampings are only the VON. The only thing that ties the VON to the VIN is the broadcast sheet.
No longer taking $h!t from anyone!
