Re: Ugg... Charging system problem (73 Satellite)
[Re: 2ndopp]
#611111
02/12/10 09:17 AM
02/12/10 09:17 AM
Posts: 15,491 the boonies
aarcuda
the boonies
blue wire is system voltage at the VR. at 10v the vr should energize the alt field to give a high output. with the green wire at 1v, that would give you about 9v cross the field on the alt and make it charge.
did you recently paint the engine? if the alt isnt grounded, it wont charge.
Measure the voltage across the battery terminals and post it.
measure the voltage across the two filed wires AT THE ALT and post it.
then measure the voltage at the Alt between the black output and the ALT case and post it.
then measure the voltage between the black output at the Alt and the Batt ground and post it.
make sure the voltage regulator CASE is grounded to the chassis. Use an ohmmeter to verify the case is grounded. also check to see the alternator is grounded. go between the case and battery ground
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
[Re: aarcuda]
#611112
02/12/10 11:14 AM
02/12/10 11:14 AM
RapidRobert
At a fast idle jump the "green wire" male alt field terminal to the alt case for 3 seconds max (not the green wire but the brass terminal).If it charges work on that circuit (from the green wire female connector over to the VR). If no go then keep the above grounded and jump fire from either the large alt batt stud (easier) or the battery positive post (try both) to the other alt male field terminal (the blue wire one) for 3 seconds & see if it charges. Still no go?, pull the brushes real quick & eyeball them. Holler back.
[Re: aarcuda]
#611115
02/12/10 06:37 PM
02/12/10 06:37 PM
Posts: 78 AZ
2ndopp
AZ
did you recently paint the engine? if the alt isnt grounded, it wont charge. No I have not Measure the voltage across the battery terminals and post it. Engine off: 12.75 Engine on dropped it to 11.8 measure the voltage across the two filed wires AT THE ALT and post it. 9.2 then measure the voltage at the Alt between the black output and the ALT case and post it. 41.6 then measure the voltage between the black output at the Alt and the Batt ground and post it. 41.6 make sure the voltage regulator CASE is grounded to the chassis. Use an ohmmeter to verify the case is grounded. also check to see the alternator is grounded. go between the case and battery ground Took off the Regulator and sanded the firewall ground spot to make sure its got good contact
[Re: hemi-itis]
#611119
02/12/10 11:13 PM
02/12/10 11:13 PM
aarcuda
the boonies
The alt is charging but the output is not making it back thru to the rest of the system. Check the voltage at the alt lead at the firewall and at both sides of the ammeter. A bad bulkhead connector or bad ammeter connections or bad ammeter.
I'd have to review the schematic to figure out where else to look.
[Re: 2ndopp]
#611121
02/14/10 10:23 AM
02/14/10 10:23 AM
aarcuda
the boonies
look, if you are getting 41v at the back of the alternator BUT only 120v or so at the blue wire, that means the alternator voltage is not making it from the alternator back to the rest of the system.
look at a schematic. the alternator output goes through the bulkhead connector and then to a slice under the dash that feeds the rest of the car including the blue wire at the VR after it goes through the ignition switch. for some reason, you have voltage at the back oif the alternator that you dont have at the VR or battery so the alt voltage isnt making back.
get a schematic and find out where the connection is broken using a voltmeter or ohmmeter
