A/C brackets for '70 E Body and 383 #61078
05/21/08 05:01 PM
05/21/08 05:01 PM
NoVa
E
ebodyseast Offline OP
E
NoVa
Need some reference pics of the A/C brackets on a '70 383, as many and from different angles and sides of engine. All the pics I have, the A/C compressor is in the way and can't see all the details - like the idler pulley and its placement.
My '70 440 with A/C uses some brackets that are similar/same pieces - a few are different parts and need to distinguish from the two to put the water pump housing and pwr steer pump together again in correct places. Thanks Moparts and Moparts members.
"Baby...you're the greatest."
Re: A/C brackets for '70 E Body and 383 [Re: ebodyseast] #61079
05/21/08 05:13 PM
05/21/08 05:13 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
I will post a few pics. 1st one is 68 383, shows the belt routing good to give you an idea how its configured.
Ron
Re: A/C brackets for '70 E Body and 383 [Re: Ronnman] #61080
05/21/08 05:18 PM
05/21/08 05:18 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Next one shows 70 pulleys and brackets.
Ron
Re: A/C brackets for '70 E Body and 383 [Re: Ronnman] #61081
05/21/08 05:32 PM
05/21/08 05:32 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
This pic is from a 70 Challenger 440 w/AC. Should be mostly configured the same as a 383 except back compressor mounting bracket.
Ron
Re: A/C brackets for '70 E Body and 383 [Re: Ronnman] #61082
05/21/08 05:33 PM
05/21/08 05:33 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Another one from the 70 Challenger.
Ron
Re: A/C brackets for '70 E Body and 383 [Re: Ronnman] #61083
05/21/08 05:34 PM
05/21/08 05:34 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Last pic from the 70 Challenger. Hope this helps some.
Ron
Re: A/C brackets for '70 E Body and 383 [Re: Ronnman] #61084
05/21/08 06:55 PM
05/21/08 06:55 PM
NoVa
E
E
NoVa
Hey Ronnman, you're the man brother, helps immensely. Thanks for helping me out. I owe you one. Call on me anytime.
Re: A/C brackets for '70 E Body and 383 [Re: ebodyseast] #61085
05/21/08 08:20 PM
05/21/08 08:20 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
it's a 1969 B-body, but it should be the same or at least very similar
http://www.hoffmanswinnerscircle.com/69rtconvertible/Engine_Related_Photos.htm
Re: A/C brackets for '70 E Body and 383 [Re: ebodyseast] #61086
05/21/08 10:23 PM
05/21/08 10:23 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Your welcome ebodyseast. I went through the same thing your going through. I collected pictures from many e and b body cars for future reference. Good luck.
Ron
Re: A/C brackets for '70 E Body and 383 [Re: Ronnman] #61087
05/22/08 01:01 AM
05/22/08 01:01 AM
NoVa
E
E
NoVa
Ronnman - I said it once, can gladly say it again, thanks brother, you should have seen those brackets of mine earlier tonight, they practically jumped into place with the pics you guys presented me for a quick reference.
The '70 440 alternator bracket of mine 'looks' to be different, a 440 is bigger and thus the bracket then possibly needs to be different. Same goes for the 440's compressor mounting brackets to the intake, appears to be different.
Can you two guys sense how much I appreciate you, hope so...
Re: A/C brackets for '70 E Body and 383 [Re: ebodyseast] #61088
05/22/08 09:20 AM
05/22/08 09:20 AM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
The following alternator brackets are preferred because they provide a very sturdy mount for the alternator. You are correct the rear compresor mount is longer for the 383-400 due to the difference in deck height.
Ron
