Cam break in lube? #610513
02/11/10 01:34 PM
02/11/10 01:34 PM
Inver Grove Heights MN
74RR Offline OP
74RR  Offline OP
What brand and type of cam break in lube is recommeded when breaking in a cam and lifters?
Re: Cam break in lube? [Re: 74RR] #610514
02/11/10 01:44 PM
02/11/10 01:44 PM
fury4speed Offline
fury4speed  Offline
Your Cam manufacturer should have given you some Cam lube for the lifter face and Cam lobe , if not they should have some. I assume they are a flat tappet type Cam , you do not need these additives if you are using a "Roller Type Cam"
You can use this:
http://www.hughesengines.com/Index/products.php?partid=23942
or this or both:
http://www.bradpennracing.com/Products/Racing-Oils.aspx
http://www.bradpennracing.com/Products/High-Performance/Break-In-Oil.aspx
They also have a "Break in" Oil.
Re: Cam break in lube? [Re: 74RR] #610515
02/11/10 05:08 PM
02/11/10 05:08 PM
I like the black Moly paste. It looks nasty and I figure it's just like medicine if it looks wicked then it's probably going to do it's job. Definitely Brad Penn oil or hughes' additive or something similar. Many good routes to go w this
Re: Cam break in lube? [Re: RapidRobert] #610516
02/11/10 06:53 PM
02/11/10 06:53 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use the Mopar lube that comes with their cams. Mopar cam lube and Valvoline racing oil and I have never had a cam wipe. Ron
