Plymouth Fury 1968 No Brake Lights #610497
02/11/10 01:32 PM
02/11/10 01:32 PM
fury4speed Offline OP
I assume it is a brake switch or the plug came off the switch , I have not looked yet so I assume there is a plug going to the switch under the dash where the brake pedal is , any other places to check if you have no Brake lights , the bulbs are good and all other lights work.
Re: Plymouth Fury 1968 No Brake Lights [Re: fury4speed] #610498
02/11/10 02:26 PM
02/11/10 02:26 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Fuse or turn signal switch. Just because the turn signals work doesn't mean the part of the switch the brake lights go through is good.
Re: Plymouth Fury 1968 No Brake Lights [Re: fury4speed] #610499
02/11/10 04:03 PM
02/11/10 04:03 PM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
Or the Hazard Flasher switch on the dash as well.
Sequence is....Brake switch by Pedal to Hazard to Turn signal switch to rear lights. Course check the fuse first.
Turn signals are notorious for that happening, got a 68 SF here with a bad one right now.
Re: Plymouth Fury 1968 No Brake Lights [Re: CHRYCOFAN] #610500
02/11/10 04:04 PM
02/11/10 04:04 PM
Andrewh Online content
Andrewh  Online Content
fuse did it for me once too.
looked good, and didn't bother to check further. Was about to rip the column apart and decided to replace it just incase and voila, lights again.
Re: Plymouth Fury 1968 No Brake Lights [Re: fury4speed] #610501
02/11/10 04:32 PM
02/11/10 04:32 PM
Pull on your hazards and if they flash OK then from the electrical connector coming out of the steering column rearward you are good. Start with: check the pink wire @ the pedal as it should be hot all the time then the pedal switch for continuity when pressed then the white wire that goes downstream on the other side of the pedal to the above connector see if it(the white wire) has fire when you press the pedal and w a circuit tester (they're cheap) w the alligator clip on a wire (connect alligator clip to ground) stab the pointed end into the electrical connector w both halves still together and w the pedal down the white wire should have fire and two wires a dark green and a brown have fire as these are the 2 "out" wires to the brake light large filaments. Check these in order until you find the "open". If the hazards do not work seperate the connector and jump fire to the aforementioned brown and dark green wire in the body half of the electrical connector and see if the brake lights work & if not work downstream until you find the "open". There are several connectors from the column rearward to the sockets and check that the sockets are grounded but most likely they are since both are not working and they probably would both not lose their grounds on opposite sides of the car at the same time.
Re: Plymouth Fury 1968 No Brake Lights [Re: RapidRobert] #610502
02/11/10 08:43 PM
02/11/10 08:43 PM
Thanks again for all your Info , I will check them out.
Re: Plymouth Fury 1968 No Brake Lights [Re: fury4speed] #610503
04/02/10 03:40 PM
04/02/10 03:40 PM
OK I finally got to check everything out , flashers and turn signals work on the outside / rear lights blink , no dash arrows are working though , no brake lights , any more Idea's? thanks.
Re: Plymouth Fury 1968 No Brake Lights [Re: fury4speed] #610504
04/02/10 03:55 PM
04/02/10 03:55 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
TS switch or brake switch.
The fact the lights work proves out the (working back) bulb grounds, bulbs wiring to the TS switch and parts of the TS switch.
It also proves the power into the TS switch, and the hazard and TS flasher and circuits.
The stuff that isn't working break down to:
1. dash indicators. The rest of the circuit is working, so either the output to them is bad, the bulbs are bad or the ground is bad.
2. Brake lights. The whole circuit is working for the flashers, so it's either the power to the brake switch, output to the TS switch or internal in the TS switch.
Check the brake switch as detailed above.
Constant power on one side, power to the other when the pedal is pushed.
Check the power at the bulb in the cluster if possible. There should be on/off power with the flashers on. That should narrow the focus.
Re: Plymouth Fury 1968 No Brake Lights [Re: RodStRace] #610505
04/02/10 06:08 PM
04/02/10 06:08 PM
So if the Brake Light Switch is Bad the Turn SignalArrows on the Dash will not light up / blink ?
Re: Plymouth Fury 1968 No Brake Lights [Re: fury4speed] #610506
04/02/10 06:49 PM
04/02/10 06:49 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
The turn signal switch !!!!! Brake lights work thru the turn signal switch.As a Dodge dealer tech in the sixties & 70's I replaced them weekly..
Re: Plymouth Fury 1968 No Brake Lights [Re: fury4speed] #610507
04/02/10 09:27 PM
04/02/10 09:27 PM
no cause w the key on the turn signals/arrows will function wo your foot on the brake. The TS's are a switched funtion whereas the brake pedal "hot pink" input is hot all the time but both are seperately fused circuits in the fuse box
Re: Plymouth Fury 1968 No Brake Lights [Re: dynamite] #610508
04/02/10 10:45 PM
04/02/10 10:45 PM
Saskatchewan, Canada
barracudabob Offline
X 2
Re: Plymouth Fury 1968 No Brake Lights [Re: RapidRobert] #610509
04/02/10 10:59 PM
04/02/10 10:59 PM
It is Funny that the lights work fine , turn signals and Em. Flh. but no Dash Arrows , would the T/S switch cause the Dash Arrows Not to Work?
Re: Plymouth Fury 1968 No Brake Lights [Re: fury4speed] #610510
04/02/10 11:23 PM
04/02/10 11:23 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Yes and so could bad bulbs in the dash and a bad ground on the dash could cause them not to flash also.
Re: Plymouth Fury 1968 No Brake Lights [Re: stumpy] #610511
04/02/10 11:49 PM
04/02/10 11:49 PM
pull apart the turn signal harness coming out of the column and jump fire to the tan and light green wires & see if that lights up the dash R & L indicator lights respectively
Re: Plymouth Fury 1968 No Brake Lights [Re: RapidRobert] #610512
04/03/10 10:52 AM
04/03/10 10:52 AM
Thanks for all your Info , I will do some checking.
