Engine Balance #610459
02/11/10 11:30 AM
02/11/10 11:30 AM
North Central, Indiana
Roughbird72 Offline OP
does anyone know what the difference is gram wise between a street balance & race balance.i know that some shops may vary.
72 Plymouth Roadrunner 11.08@123.25
Re: Engine Balance [Re: Roughbird72] #610460
02/11/10 12:19 PM
02/11/10 12:19 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I don't thing it's an actual weight issue as much as it has to do with tolerences allowed.
Re: Engine Balance [Re: WILD BILL] #610461
02/11/10 02:55 PM
02/11/10 02:55 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I'd say it doesn't have to do w/ the tolerances involved as the level of effort put into the balancing job.
Re: Engine Balance [Re: Roughbird72] #610462
02/11/10 03:22 PM
02/11/10 03:22 PM
I have seen and heard of as much as 18 grams differences in stock pistons and rods, most good balance shops shoot for one gram variences on rods(with bearings and oil), pistons (with wrist pins and rings) on there balance jobs. Some achieve that and some don't I have a Haus triple beam balance scale so I do check the parts now and then just to keep the shops on thier toes BTW, to do balance checking properly you need a shadow graph and a crankshaft balancing machine, which I don't have
Re: Engine Balance [Re: Cab_Burge] #610463
02/11/10 10:12 PM
02/11/10 10:12 PM
ok i was a little vague.i was more interested in tolerances in grams.i have done my 440s & a few small chevys at a friends shop.i've always tried to keep pistons/pins & rods within 2 grams & crank within 5 grams on street/strip engines.
Cab i had a set of LY rods that varied 14 grams on the big end.
Re: Engine Balance [Re: Roughbird72] #610464
02/11/10 11:41 PM
02/11/10 11:41 PM
some shops seem to have that "it's good enough" mentality.
if your shop has different balance jobs for different engine jobs, i'd look elsewhere.
we take the approach of either it's done right, or we won't do it.
Re: Engine Balance [Re: Roughbird72] #610465
02/12/10 12:35 AM
02/12/10 12:35 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Matching the weights is the high school stuff.
Knowing where to remove the weight from the crank is a whole different game.
Boffin Emeritus
Re: Engine Balance [Re: polyspheric] #610466
02/12/10 12:43 AM
02/12/10 12:43 AM
fortunately,i've had access to a hines balancer.
Re: Engine Balance [Re: Roughbird72] #610467
02/12/10 08:10 PM
02/12/10 08:10 PM
QLD Australia
Keith Black® Offline
QLD Australia
race balance will likely over balance +/- 0.5-1%
Darren Beale
Keith Black Racing Engines®
