Brake issue, wont lock up
#609926
02/10/10 06:11 PM
02/10/10 06:11 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Ive finally decided to take a look at the brakes on my RR.
My issue is neither the front or rear will lock up, Ive tried several panic stops and they just wont lock. What I have are 10.5 inch discs robbed from a 72 Challenger and stock 11 inch drums in the rear. I have a MP master cylinder, (cant remember bore size, but I believe its the bigger bore size), I also have a Wildwood Prop valve in the rear line.
At the track the brakes seem to work just fine. They slow it down just fine, with no fade.
They get the job done on the street, but just dont lock.
Opinions?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Brake issue, wont lock up
[Re: Von]
#609929
02/10/10 08:14 PM
02/10/10 08:14 PM
Posts: 25,960 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If the brakes seem to work just fine at the track and they get the job done on the street why worry about not locking up?
[Re: John_Kunkel]
#609931
02/10/10 11:12 PM
02/10/10 11:12 PM
Posts: 4,884 Michigan
MNobody
If they work good don't screw with it, i've learned that from trying to make things better and got burned trying..
[Re: John_Kunkel]
#609933
02/11/10 10:22 AM
02/11/10 10:22 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
Cuz when on the street and that 80 YO guy in the Buick stops short to pull into Walgreens....
You need to lock'em up. Rethink the whole MC thing. It's NOT working.
[Re: Commando1]
#609934
02/11/10 07:08 PM
02/11/10 07:08 PM
John_Kunkel
Rio Linda, CA
Which stops better, skidding tires or tires with traction? (think ABS)
[Re: John_Kunkel]
#609935
02/11/10 08:17 PM
02/11/10 08:17 PM
Posts: 4,179 California
mickm
California
skidding tires stop better. just think of the pads trying to slow the car down by gripping the rotors, or the rubber of the tires digging into all the tiny grooves and irregularities of the pavement. dragging non-rotating rubber along the pavement is a hell of a stopping force.
but you also then have no steering control. ABS is to keep the tires from locking up so you have steering control.
[Re: mickm]
#609936
02/11/10 08:28 PM
02/11/10 08:28 PM
Posts: 3,905 Oregon
hooziewhatsit
Actually, skidding tires provide less stopping power than rolling tires.
The thing I'd be concerned about is the additional breaking you're giving up by having the system not able to lock up the brakes.
[Re: hooziewhatsit]
#609939
02/11/10 10:32 PM
02/11/10 10:32 PM
Von
NE Oklahoma
[quoteThe thing I'd be concerned about is the additional breaking you're giving up by having the system not able to lock up the brakes.
Thats what concerns me also!!
BTW, Ive concluded its the bore size of the master. I dont have any kinked or collapsed lines and since none of the brakes lock up, that eliminates a line issue. I doubt its the pedal, as its from a factory manual brake car.
Im changing motors in the next few months so I'll swap masters at that time.
Im also sure now that the master is the bigger bore MP master.
Anybody tried the RedBore master yet?
