Re: Frame connectors for 64 Savoy?
[Re: silverfish]
#60964
05/21/08 02:20 PM
05/21/08 02:20 PM
Posts: 4,285 Ohio
64dodge572
Ohio
I used 2" box on my 64 and cut the one end to match the rear frame rail angle. I had less than $20 in the project.
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: wings471]
#60968
05/21/08 03:50 PM
05/21/08 03:50 PM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
I also used 2X2X1/8 for my frame connectors on my '65 B body. Just make sure that everything is clean and that the car is supported on its suspension before welding.
This is the land of the free
because of the brave
[Re: ZIPPY]
#60970
05/22/08 08:35 AM
05/22/08 08:35 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
The mancini kit is the same for all b bodys 62-70. I do not like the looks of them I am not a big fan of square tubing. We make our own out of round tubing and weld in.
JAKES AUTOMOTIVE
[Re: JAKE68]
#60971
05/22/08 08:53 AM
05/22/08 08:53 AM
Posts: 1,443 Maryland
Dads426
Maryland
2x3" tubing will have to go through the floor at the rear pan; 2x2 will fit beneath it. It is a straight shot from the torsion bar mount to the rear frame rails. We cut the diagional section off the rear frame rail and slipped the tubing inside it. You can drill a 1" hole in the frame rail and weld a rosette weld to the connector and along the diagional section of the frame rail. It will be plenty strong.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
