question on removing the third member (pumpkin) #609513
02/10/10 01:13 PM
02/10/10 01:13 PM
Dallas, TX
71monaco Offline OP
71monaco  Offline OP
Dallas, TX
Folks,
I've got a 71 monaco and I need to drop/pull the third member. My only problem is that my garage is not wide enough to pull the axles all the way out of the housing. Can I disconnect them from the third member and rest them inside the housing? If so, how far do I need to pull them out?
btw....how do they come out anyway? :-)
Thanks,
David
Re: question on removing the third member (pumpkin) [Re: 71monaco] #609514
02/10/10 01:14 PM
02/10/10 01:14 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
how much room do you have? you should be able to pull them out part way ..becareful not to damage seals.. you will need to unbolt the axle..from brake side..a good tap on backing plate should free them up so you can remove axle..
Re: question on removing the third member (pumpkin) [Re: 340dart4spd ] #609515
02/10/10 01:17 PM
02/10/10 01:17 PM
Dallas, TX
71monaco Offline OP
71monaco  Offline OP
Dallas, TX
i might have like a foot or two on each side if i can arrange the car just right...
Re: question on removing the third member (pumpkin) [Re: 71monaco] #609516
02/10/10 01:20 PM
02/10/10 01:20 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
sould work..but it is prob gonna be hard to remove wheels..or room to work...
Re: question on removing the third member (pumpkin) [Re: 71monaco] #609517
02/10/10 01:25 PM
02/10/10 01:25 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
It's not necessary to remove the axles, 7-8 inches on each side should do it. As was already said having enough room to get the tires and brake drums off might be an issue.
Re: question on removing the third member (pumpkin) [Re: 5spdcuda] #609518
02/10/10 01:27 PM
02/10/10 01:27 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
What he said ...
Re: question on removing the third member (pumpkin) [Re: 5spdcuda] #609519
02/10/10 01:29 PM
02/10/10 01:29 PM
Dallas, TX
71monaco Offline OP
71monaco  Offline OP
Dallas, TX
It should be ok...
how do the axles come out after i get the rear brakes off?
Re: question on removing the third member (pumpkin) [Re: 71monaco] #609520
02/10/10 01:42 PM
02/10/10 01:42 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Five nuts per side holds the axle/seal retainer. Right side also has the end play adjuster and a metal hook which goes under one of the nuts to prevent the adjuster from moving once end play is set. .008-.012 end play is about right. You may have to remove the bar above the retainer that holds the brake shoes apart in order to pull the axles. Don't know what the weather is like in "Big D", but if you get any warm weather soon I would do it outside where you have more room.
Re: question on removing the third member (pumpkin) [Re: 71monaco] #609521
02/10/10 01:44 PM
02/10/10 01:44 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
There are 5 nuts that hold them to the axle housing it self.The axle has a hole in it that a 9/16 3 /8 drive socket fits thru.Take the nuts off and the axles should pull out.Sometimes they need some persuasion.You can put the drum on back wards and pull on it if they dont pop right off.Rocky
Chrysler Firepower
Re: question on removing the third member (pumpkin) [Re: therocks] #609522
02/10/10 02:39 PM
02/10/10 02:39 PM
scratchnfotraction Offline
yep pull axle 7-8 inches
then the 10 nut on the chunk
I leave 1-2 nuts on and pry it from the seal some to drain the gear oil
after draining remove the nuts and pull the ham out
be ready its about 80-85 lbs
I use a floor jack and help hold it down
just be carefull when up on stands and droping/lifting it in out
with the axles out would be a good time to use a greese needle and repack the bearing rollers
they do not get the diff gear oil but are packed with greese like a front wheel bearing
why are you pulling it out??
Re: question on removing the third member (pumpkin) [Re: 71monaco] #609523
02/10/10 04:37 PM
02/10/10 04:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Allowing the weight of the axles to rest on old stiff seals is a good way to ruin the seals.
Re: question on removing the third member (pumpkin) [Re: scratchnfotraction] #609524
02/10/10 06:19 PM
02/10/10 06:19 PM
Dallas, TX
71monaco Offline OP
71monaco  Offline OP
Dallas, TX
well, i originally bought a sure-grip clutch type third member from Dr. Diff and had my mechanic install it for $300. shortly after it started making loud noises...I took it back and my mechanic removed it and saw the spider gears were broke. we sent the 3rd member back to Dr. Diff and he sent another back. My mechanic installed that and now it's starting to make similiar noises. Instead of paying my mechanic another $300, i'm just going to tackle it myself.
What could cause the spider gears to keep breaking? we used the correct fluid as well friction modifier.
PS. I don't mean to knock Dr Diff at all. He has been very helpful and he reimbursed my shipping for the first unit. He replies to my emails very quickly, and with this new problem he suggested we remove the third member again to view the problem. The only issue is that I don't want to pay my mechanic, so I need a little help from the board so I can save the money. :-)
Re: question on removing the third member (pumpkin) [Re: 71monaco] #609525
02/10/10 06:30 PM
02/10/10 06:30 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
I would find a new mechanic..
Re: question on removing the third member (pumpkin) [Re: 340dart4spd ] #609526
02/15/10 07:19 PM
02/15/10 07:19 PM
Dallas, TX
71monaco Offline OP
71monaco  Offline OP
Dallas, TX
is 300 too much to replace the third member?
Re: question on removing the third member (pumpkin) [Re: 71monaco] #609527
02/15/10 07:25 PM
02/15/10 07:25 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
The last pig I changed took me 30 minutes ....and that was ON THE GROUND .... and no air tools.
YES .....I would say 300$ is way WAY out-of-line.
Re: question on removing the third member (pumpkin) [Re: dOc !] #609528
02/15/10 08:51 PM
02/15/10 08:51 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
All good info above on pulling the center. After you get the center out, CAREFULLY slide the axles back in so they don't rest on the seals any longer than necessary. Slightly turning the axle shaft as you pull it out and then as you put it back can help prevent tearing the seal. With the limited space you have, it sounds like you would have to cut a hole in the wall if you had to change an axle seal.
Master, again and still
Re: question on removing the third member (pumpkin) [Re: 71monaco] #609529
02/15/10 10:45 PM
02/15/10 10:45 PM
Retired now in Tennessee
Chi_Town_Runner Offline
You don't need to remove the brakes. Just the brake drum. It will unbolt and the axles will slide out with the brake shoes in place.
Frank
EDIT: That's how my '68 is not sure about a Monaco
Remember - 2 wrongs don't make a right - but 3 rights make a left!
