Block clearance for stroker crank #609288
02/09/10 11:14 PM
02/09/10 11:14 PM
Olin, NC
dutch165 Offline OP
dutch165  Offline OP
Olin, NC
I have a 493 stroker kit going in a 1978 440HP block that came out of a NC Highway Patrol car. Does the block need clearanced? Local machine shop says no, stroker kit was purchased from Mancini Racing.
Re: Block clearance for stroker crank [Re: dutch165] #609289
02/09/10 11:23 PM
02/09/10 11:23 PM
St Louis, MO, USA
srunge55 Offline
srunge55  Offline
St Louis, MO, USA
It should not need to be clearanced especially if you bought the kit with the Chevy size rods (2.20 inch).
Re: Block clearance for stroker crank [Re: srunge55] #609290
02/09/10 11:32 PM
02/09/10 11:32 PM
Olin, NC
dutch165 Offline OP
dutch165  Offline OP
Olin, NC
Thanks for the reply, I'm not sure of the rod length.
Re: Block clearance for stroker crank [Re: dutch165] #609291
02/09/10 11:49 PM
02/09/10 11:49 PM
St Louis, MO, USA
srunge55 Offline
srunge55  Offline
St Louis, MO, USA
2.20 inches is the size of the rods big end where it connects to the crank. The Chevy journal size will give you more clearance.
Re: Block clearance for stroker crank [Re: srunge55] #609292
02/10/10 01:22 AM
02/10/10 01:22 AM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
But if it has stock mopar rod size ends it will need some clearance ground bottom of cylinders and at the oil pickup.
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
