How to Measure Drums??? #609247
02/09/10 09:54 PM
02/09/10 09:54 PM
440charger70 Offline OP
super street
super street
I have some drums I am wanting to sell and need to know how to measure what size they are. Is this measured from the outside case or from inside the drum case? The outside is 13", but I have not had time to measure the inside. How do I measure and/or what size would a 13" case be?
Re: How to Measure Drums??? [Re: 440charger70] #609248
02/09/10 09:59 PM
02/09/10 09:59 PM
Ft.Myers,Florida
Hemiruss Offline
Hemiruss  Offline
Ft.Myers,Florida
You measure on the inside drum to inside drum face(wear area that the brakes contacts) Sometimes you should measure the width,you'll it later when ordering shoes.
Re: How to Measure Drums??? [Re: Hemiruss] #609249
02/09/10 10:32 PM
02/09/10 10:32 PM
scratchnfotraction Offline
across the middle inside to inside
then across the section the shoe rides on
sounds like 11" x 2 or 11x2.5
you also look at the lug holes for the correct bolt pattern
like 5 on 4.5 or 5 on 5.5 on 85 up trucks
measure the center of the stud hole,skiping one hole to the center of the next one
most likly for a car and 5 on 4.5
but I would check to make sure they are not truck drums,IMO
