Re: Predator horsepower
[Re: 572stealth]
#609172
02/09/10 11:01 PM
02/09/10 11:01 PM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
Mine as well as others on this board were up and running waaaaaaaaay before elvis!! Mine 572" cam way bigger than the one you posted, with a 2 1/2 " primary (24"long)and a 4 1/2" merged collector made 1231 hp and 865 lb. tq.
Post deleted by Defbob
[Re: forphorty]
#609174
02/09/10 11:27 PM
02/09/10 11:27 PM
[Re: Irun5snd8th]
#609176
02/10/10 12:41 AM
02/10/10 12:41 AM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
What about Wheatcrafts Neon, If I recall it has Predator power to..Someday I will have a car worthy of Predator Power. I woudl think with a 598 1200 is a no brainer, so to speak. If my little B1 can make 1050 then you shoudl be there easy.
[Re: Al_Alguire]
#609177
02/10/10 12:53 AM
02/10/10 12:53 AM
Posts: 2,864 IN
Irun5snd8th
IN
Chris still has the Neon as well and it is also Predator powered. That thing is over 1200 and seems to be easier on parts than the motor in the digger but I believe there is about a 100 hp difference between the two engines. Nevertheless most of these engines are 1100+ HP
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: Triple Threat]
#609179
02/10/10 01:36 AM
02/10/10 01:36 AM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
Go greens car has enough power to go 203 on 10.5's.. Don't know what it weighs, but it makes a buttload of power.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: 572stealth]
#609180
02/10/10 02:02 AM
02/10/10 02:02 AM
Posts: 614 new jersey
gillman34
new jersey
I'm getting ready to build a Predator motor for a customer and I'm looking for some real world power numbers. The motor is 592", Ken spec'ed a cam of .929"In .875"exh with 283/308. Also looking for recommendations on header sizes.
What manifold?cast t/r or sheetmetal t/r? That cam should be OK albiet a little short on lift and int duration. 2-1/4 2-3/8 2-1/2 into a 4.5" collector approx 13" long My estimate is 1275hp Let us know how you make out!
[Re: 572stealth]
#609181
02/10/10 05:19 AM
02/10/10 05:19 AM
Posts: 345 iowa
wesw
iowa
my 588 predator is a little over 1200 hp with out the nos. it's set up with two systems on it.
598 ci predator
[Re: Irun5snd8th]
#609183
02/10/10 11:44 AM
02/10/10 11:44 AM
Posts: 901 oh
julian2007
oh
I think the neon is a 604 and it is for sale on rj herd he is going bigger.
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
[Re: HotRodDave]
#609186
02/10/10 12:17 PM
02/10/10 12:17 PM
Posts: 4,048 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Elvis...told us and showed us everything he knew about them
Like camshaft, piston, and intake manifold particulars? NO he hasn't.
