JUST GOT A CONFIRMATION THAT AN ORIGINAL CAST IRON 4V INTAKE, PART NUMBER 3462848 DATED B-23-1, (FEB. 23, 1971) FOR A SMALL BLOCK MOPAR 340 ENGINE MEASURES 4 1/2" FROM THE CARB BASE TO END SEAL. I BELIEVE THAT IS A 1970 PIECE AND A 1971 WOULD BE THE SAME HEIGHT. THIS MEANS THAT IF I USE THE EDDY AT 5.350" AND ADD A 1/2" NITROUS PLATE I'M ONLY ABOUT 1 3/8" TALLER. SURELY I COULD MAKE THAT WORK WITH A SHAKER...NOW IF I COULD FIGURE OUT IF A THERMOQUAD IS TALLER OR SHORTER THAN A HOLLEY...?
