70 six pack linkage #608321
02/08/10 10:45 PM
02/08/10 10:45 PM
appleton,wis
moparrookie Offline OP
appleton,wis
where the acc. cable attaches to the center carb with the U shaped clip should there be a bushing. The hole in the carb is much larger than the special bolt used.
Re: 70 six pack linkage [Re: moparrookie] #608322
02/08/10 10:59 PM
02/08/10 10:59 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
There should be a nylon washer on each side along with a nylon bushing on the shaft. So that piece with the long groove in it slides only on nylon.
Re: 70 six pack linkage [Re: moparrookie] #608323
02/09/10 02:11 AM
02/09/10 02:11 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I think the OP is refereing to were the throttle stud/nut assy is placed on the center carb to attach the cable link and hairpin clip,...he's probally missing the stud assy/clip
