New piston question??? #608284
02/08/10 09:52 PM
02/08/10 09:52 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
I have a new set of Ross dome pistons .030 440.
They have a "ridge" between the valve reliefs. I hope you cansee it in this picture.
Q: Do I need to remove this ridge? What about the other "sharp" edges on the dome and around the plug relief? Should they be masseged or run as is?
I just realized that in 20 some years of racing, this is the FIRST set of NEW pistons that I'VE ever had! Always bought someone else's hand-me-downs.
Re: New piston question??? [Re: '72CudaRacer] #608285
02/08/10 09:54 PM
02/08/10 09:54 PM
Mooresburg, Tn
Mooresburg, Tn
Another angle
Re: New piston question??? [Re: '72CudaRacer] #608286
02/08/10 09:58 PM
02/08/10 09:58 PM
Cab_Burge Online work
Cab_Burge  Online Work
I try not to run any sharp angles in the comustion chamber, take the sharp edge off with a small knife, don't take a bunch off, just round the edge off so it won't cut you or feel sharp
Re: New piston question??? [Re: '72CudaRacer] #608287
02/08/10 10:10 PM
02/08/10 10:10 PM
alaska,usa
9
9secondsatellite Offline
alaska,usa
they haven't been balanced yet i take it. are you going to coat them? i would round out the edges but nothing radical. don't need to remove the ridge but just smooth it with some very fine stuff.
Re: New piston question??? [Re: Cab_Burge] #608288
02/08/10 10:14 PM
02/08/10 10:14 PM
Mooresburg, Tn
Mooresburg, Tn
I was thinking That I'd use very fine sand paper to just "knock off" the edge. Any thoughts about that?
Re: New piston question??? [Re: 9secondsatellite] #608289
02/08/10 10:17 PM
02/08/10 10:17 PM
Mooresburg, Tn
Mooresburg, Tn
No, not balanced yet. Planing to do that sat. Coat them with what?
Re: New piston question??? [Re: '72CudaRacer] #608290
02/08/10 10:30 PM
02/08/10 10:30 PM
alaska,usa
9
alaska,usa
heat barrier coating is what i was refering to. probably not necessary.
Re: New piston question??? [Re: 9secondsatellite] #608291
02/08/10 10:32 PM
02/08/10 10:32 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Yep
Nock the sharp edges down how ever you can.
Re: New piston question??? [Re: Bob_Coomer] #608292
02/08/10 10:42 PM
02/08/10 10:42 PM
Mooresburg, Tn
Mooresburg, Tn
Thats what I was thinking, but wanted to make sure. What about the edges of the piston crown. (if it was a flat top, the top edge)? Leave it alone, or smooth it also?
Thanks guys, Brian
Re: New piston question??? [Re: 9secondsatellite] #608293
02/08/10 11:52 PM
02/08/10 11:52 PM
South Jersey
kruger Offline
Yours Too!
kruger  Offline
Yours Too!
South Jersey
I have those same pistons.Just take a dremmel with a fine roll and just radius the sharp edges around the dome.Then polish them up.
As stated above,nothing radical.Just imagine making a sharp right turn at a lite.
