Re: TTI Headers Sizing
[Re: Sunroof_Cuda]
#607999
02/10/10 12:23 AM
02/10/10 12:23 AM
Posts: 603 Central Oregon
Rodney
Central Oregon
I have an opportunity to pick up some low mileage big block headers for an E body. I have a fresh, near stock cam, 4 speed, aftermarket carb, standard compression 440. I probably would have thought the 1 3/4 inch would be right, but these are 2" diameter. Thoughts on suitability?
you should be good to go with a standard trans a+. you didn't mention the gear ratio of the rear end? you could also grow into them!
[Re: Sunroof_Cuda]
#608000
02/10/10 11:05 AM
02/10/10 11:05 AM
BradH
FWIW, on different street/strip 440s I've built, I've gone... - 12.2s w/ 1-3/4" headers... - 11.0s w/ 1-7/8"... - 10.5s w/ 2" Going too big on header size will cost you torque w/o necessarily any offsetting improvements in peak HP, either.
