Freeze plug question #60771
05/21/08 07:07 AM
05/21/08 07:07 AM
Palm Coast, FL (near Daytona B...
Blown_Hemi Offline OP
I came across a JY motor that has a small washer glued to the freeze plug. It reads " Pioneer Void if Removed". What are these? I have never ran across something like this before.
Ask me my opinion of Frank Mitchell....... A Mopar crook!
Re: Freeze plug question [Re: Blown_Hemi] #60772
05/21/08 08:12 AM
05/21/08 08:12 AM
scratchnfotraction Offline
jy use them,they are a thermal thingy that will melt and come off if it runs hot
they will not replace it,no warranty for a used engine that has gone bad
just there way of knowing if its been run hot
I think about 260* its melted and off
Re: Freeze plug question [Re: scratchnfotraction] #60773
05/21/08 09:55 AM
05/21/08 09:55 AM
Piqua, Ohio
dodgeram440 Offline
Happy Birthday dodgeram440  Offline
Piqua, Ohio
Actually, they are used on reman/crate engines for the same reason. If you found one on a jy engine, chances are it's a reman. I really doubt that after taking shortcuts removing the engine like cutting hoses, clipping wires and torching mounts and brackets, a jy will take the time to replace a freeze plug. Maybe they do in your area, but around here they don't.
Re: Freeze plug question [Re: dodgeram440] #60774
05/22/08 07:12 AM
05/22/08 07:12 AM
Thanks guys. I thought maybe that is what they were. I have just never have seen them before, heard about things like that though on reman engines. I will take a torch to them and see if they do melt. There was one on each cylinder bank.
Re: Freeze plug question [Re: Blown_Hemi] #60775
05/22/08 10:10 AM
05/22/08 10:10 AM
yea reman engines from auto zone and places will have them
around my area they are on better up scale jy that sell the barly used auto parts
and yes I have got them all cut out and have the ends still attached to the engine from them as well,they call it a complete engine,all sender units and most of the stock wire connections will be there also
