5.7 Hemi Swap Computer programing? #607362
02/07/10 08:34 PM
02/07/10 08:34 PM
Rome, Ga
sbhpcb Offline OP
sbhpcb  Offline OP
Rome, Ga
I have the 5.7 on a stand for testing. I have heard of S&P, Hotwire auto, And B&G. Has Anybody had Good or bad experinces with any of these Folks? Any Others? Will the Hemi run at idle on the stand with out the transmission wired up? Or Do I have to have the Computer programed to Test run?
Re: 5.7 Hemi Swap Computer programing? [Re: sbhpcb] #607363
02/07/10 09:53 PM
02/07/10 09:53 PM
dbogie Offline
dbogie  Offline
A few people I know have used Hotwire with success.IMO they pioneered this modern hemi transplant.I know there's someone out there taking existing wiring harnesses and making them work in your car for a lot less.(maybe someone on ebay).Had a hard time getting ahold of someone at B&G for a flash.You need a flash, I used a 04 ram manual 5.7 flash.
Re: 5.7 Hemi Swap Computer programing? [Re: dbogie] #607364
02/07/10 10:58 PM
02/07/10 10:58 PM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
I used hotwire. they have helped me throughout. Really nice folks to work with. high quality wiring, looks factory. I used 5.7 04' man. tranny puter flashed to run my 6.1. simple hookup. Also, if I remember, it really only needs cam and crank position sensors hooked up to run.
Re: 5.7 Hemi Swap Computer programing? [Re: hemibeep] #607365
02/08/10 11:03 AM
02/08/10 11:03 AM
Arizona
69rrconvert Offline
69rrconvert  Offline
Arizona
I used Hot Wire for my 04 Hemi install in my 69 rr. They make a great harness with everything well labled. I had a few questions during the install and Chris from Hot Wire was great and answered all of my questions. They also flashed the computer for me
Re: 5.7 Hemi Swap Computer programing? [Re: 69rrconvert] #607366
02/08/10 11:24 AM
02/08/10 11:24 AM
Almont, MI.
gdemon Offline
gdemon  Offline
Almont, MI.
Im using a 2004 Ram Manual trans computer also. I had mine flashed by B & G . I little hard to get a hold of but seems to work great. By the way it will start and run with a factory flash. I ran mine for a month like that with no problems. It just runs a lot stronger with a custom tune.
69 Barracuda 70 Cuda 70 Cuda 70 Cuda Conv. 70 T/A Challenger 70 Sport Fury GT 71 Demon 5.7 Hemi 72 Demon
Re: 5.7 Hemi Swap Computer programing? [Re: hemibeep] #607367
02/08/10 02:42 PM
02/08/10 02:42 PM
Canada
DmanSRT71 Offline
DmanSRT71  Offline
Canada
Anyone have the Chrysler part number for that 2004 ram manual trans computer?
I can't find a used one advertised (ebay etc), but a few yards have a few versions of the manual trans computer, so I need to know which works (if there's a difference).
Any help is appreciated.
69 Road Runner 383/auto/N96 71 Demon 340/4 spd Would like to find a rust free Cuda body.
Re: 5.7 Hemi Swap Computer programing? [Re: DmanSRT71] #607368
02/08/10 09:17 PM
02/08/10 09:17 PM
Rome, Ga
sbhpcb Offline OP
sbhpcb  Offline OP
Rome, Ga
Thanks for the info Guys. I called Chris at Hotwire 479 243 9115 He tells me that they can now Flash the Auto ECU's and make them perform as well as the 2004 manuel ECU's. He is a very helpful Guy. The other folks I spoke with said I would have to buy a 2004 manuel ECU for them to be able to Flash. Chris and somebody else I spoke with said that the 2005 Dodge 1500 ECU is the best to have. I really did not grasp why But I hope it helps.
Re: 5.7 Hemi Swap Computer programing? [Re: sbhpcb] #607369
02/08/10 09:28 PM
02/08/10 09:28 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
Most people have the 04 Ram manual trans computer, because like myself and GDEMON,we started this swap and had it running two-three years ago, and this is what was needed to make it run. Now with the new technology it is not needed...
The 6.1 hemi computers (auto version) apparently can be flashed too, by Dave at B&G.
At one time Chris Squire told me his flash was not very performance orientated. Meaning he could make it run well, but if you wanted more power, revised rev limiter, etc, B&G was better. Again two to three years ago...
justin
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: 5.7 Hemi Swap Computer programing? [Re: wldtm] #607370
02/08/10 10:15 PM
02/08/10 10:15 PM
Canada
DmanSRT71 Offline
DmanSRT71  Offline
Canada
I called B&G something like 6 months ago and they told me to get the 04 ram computer. I questioned this, since the webpage actually states "yes we can make an auto computer into a manual" and was told it was still better to get the ram computer.
justin
Re: 5.7 Hemi Swap Computer programing? [Re: DmanSRT71] #607371
02/09/10 11:30 PM
02/09/10 11:30 PM
Rome, Ga
sbhpcb Offline OP
sbhpcb  Offline OP
Rome, Ga
Thanks Again for the Help. I did get the 5.7 Hemi on the test Stand to fire off today. It really sounded good to hear my Wiring Haircut Running. I am sure I will be asking for more advice in the future as I proceed to fit it in the car and hopefully get a 5 speed to row gears with. Thanks again.
Re: 5.7 Hemi Swap Computer programing? [Re: sbhpcb] #607372
02/10/10 10:29 AM
02/10/10 10:29 AM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
Congrats....
justin
Re: 5.7 Hemi Swap Computer programing? [Re: DmanSRT71] #607373
02/10/10 10:20 PM
02/10/10 10:20 PM
Hesston, KS
boden Offline
boden  Offline
Hesston, KS
My favorite way to find part numbers is through www.moparpartsamerica.com They have the PDF parts catalogs. You have to sign up for an account to access them though. From what I could find there are multiple 2004 manual trans part numbers including
56029035AA
56029147AA
56029151AA
56030033AA
56031034AA
Re: 5.7 Hemi Swap Computer programing? [Re: boden] #607374
02/11/10 09:14 AM
02/11/10 09:14 AM
Almont, MI.
gdemon Offline
gdemon  Offline
Almont, MI.
I looked those up and it seems that all those part numbers are now superseded to 05094273AA
Re: 5.7 Hemi Swap Computer programing? [Re: gdemon] #607375
02/11/10 10:06 AM
02/11/10 10:06 AM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
jerry... i couldnt get a price on that one. it comes up as no part number found.
all the other ones show no price....
justin
Jerry call me... I am getting ready to start on the harnesses. Your PM box must be full.
Re: 5.7 Hemi Swap Computer programing? [Re: wldtm] #607376
02/11/10 11:44 AM
02/11/10 11:44 AM
Almont, MI.
gdemon Offline
gdemon  Offline
Almont, MI.
Hi Justin
I added a extra number. Here is the correct one. 05094273AA and that superseds to RL094273AA. Ill call you tonight on the Harness. For some reason the RL number lists a core charge.
Jerry
Re: 5.7 Hemi Swap Computer programing? [Re: gdemon] #607377
02/11/10 11:56 AM
02/11/10 11:56 AM
Ohio
racerAL Offline
racerAL  Offline
Ohio
Hi Justin
Jerry
...theres a core charge because it's a re-man part- hence the RL in the part #.
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
Re: 5.7 Hemi Swap Computer programing? [Re: gdemon] #607378
02/11/10 12:01 PM
02/11/10 12:01 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
Hi Justin
Jerry
Out of the two harnesses you sent me, which one can i disect to make one good one for the car?
One has a big connector..maybe from a jeep or durango
The other one looks like a truck...
Re: 5.7 Hemi Swap Computer programing? [Re: wldtm] #607379
02/11/10 11:29 PM
02/11/10 11:29 PM
OH
Red383 Offline
Red383  Offline
OH
I have this document, pretty helpful when looking for a certain box.
5798559-DodgeFlashAvail.pdf (1770 downloads)
Re: 5.7 Hemi Swap Computer programing? [Re: Red383] #607380
02/11/10 11:52 PM
02/11/10 11:52 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
Now that is a handy document...
Re: 5.7 Hemi Swap Computer programing? [Re: wldtm] #607381
02/12/10 12:12 AM
02/12/10 12:12 AM
OH
Red383 Offline
Red383  Offline
OH
I thought so. I found it surfing the net. So far I have found it pretty accurate. Hope it helps some others out there.
Aaron
