Re: Wich Head Gasket to use
[Re: MR_P_BODY]
#607223
02/07/10 05:18 PM
02/07/10 05:18 PM
Posts: 228 northeast texas
strokin73cuda
northeast texas
Its supposed to be around 11 to 1 I haven't got the heads back from Dwayne yet so I'm not sure.
496 stroker,Indy srs , new best 6.87 @ 98 1.46 60'
[Re: strokin73cuda]
#607224
02/07/10 05:25 PM
02/07/10 05:25 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Just ask Dwayne which gasket he would suggest, I would just use a Felpro... they have always worked well for me but 90% of my engine stuff is SB ![](/ubbthreads/images/graemlins/wave.gif)
[Re: strokin73cuda]
#607226
02/07/10 06:10 PM
02/07/10 06:10 PM
MR_P_BODY
The felpro gaskets I used with Eddy heads had the fire rings real close to the edge of the cylinders he also brought this up when I was talking to him about the using the SRs. And at the time I told him I would probably order some cometecs but I'm not sure now after reading about people having trouble with them leaking water.
Felpro makes a couple of different bore sizes, dependent on your bore
[Re: MR_P_BODY]
#607227
02/07/10 06:31 PM
02/07/10 06:31 PM
strokin73cuda
northeast texas
Bore is 4.360. What size fire ring is recomended?
[Re: strokin73cuda]
#607228
02/07/10 06:34 PM
02/07/10 06:34 PM
MR_P_BODY
something larger than your bore... I dont recall the different diameters that Felpro offers... check with Dwayne ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#607229
02/07/10 07:31 PM
02/07/10 07:31 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
i use felpro 1009,s on my sr motor.it has 13.2 cr.i think it is a 4.400 bore size,.039 thick
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: Old School]
#607230
02/07/10 07:40 PM
02/07/10 07:40 PM
Posts: 43,307 Bend,OR USA
Cab_Burge
I blew a set of the Fel pro race 1009 and a set of the stanadrd duty 8517 PT out in my 4.380 bore with SR heads twice(12.9 to 1 comp. ratio) ![](/ubbthreads/images/graemlins/rant.gif) Get the larger bore race and marine gaskets for the 4.440 bore size ![](/ubbthreads/images/graemlins/Twocents.gif) Or a set of the Edelbrock head gaskets for the 4.440 size bore ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Cab_Burge]
#607231
02/07/10 07:46 PM
02/07/10 07:46 PM
Old School
Virginia Beach, VA
if you need a bigger bore felpro,i use a 1039 in my 580" motor.it is 14.1 cr.i think it is 4.590" bore and .051" thick. i have had zero problems with both of theese gaskets.i also use head studs.
[Re: strokin73cuda]
#607233
02/07/10 08:20 PM
02/07/10 08:20 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
Dewayne told me to use a set of Fel-Pro 8519 gaskets with my 0.030 440. if i understood him right he said they were good to 12.1 compression.mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: Cab_Burge]
#607234
02/13/10 10:29 PM
02/13/10 10:29 PM
strokin73cuda
northeast texas
I ordered the edelbrock 8519pti gaskets 4.450 .038 compressed and they came in an edel pakage but they have mr.gasket stamped on them ![](/ubbthreads/images/graemlins/whistling.gif) . They measure 4.50 perpindicular and parallel and .047-.051 thick ootb they look goood on the block we'll see what they look like when the heads get here. I was leaning toward MLS gaskets but the machine work on the block didn't look to be smooth enough ![](/ubbthreads/images/graemlins/tsk.gif) .
