A-12 hi-po exhaust manifolds for 3/29 dated car #607205
02/07/10 04:01 PM
02/07/10 04:01 PM
Indiana
F6F6Dodge Offline OP
Indiana
I am looking for a set of these for a m-code car built on 3/29....does anyone know what numbers or date codes should be on the correct set of manifolds to match a 3/29 car??? Thanks for any and all help!!!!RH SIDE # 2806900 THE LEFT SIDE #2843992 what do these numbers mean???
Re: A-12 hi-po exhaust manifolds for 3/29 dated car [Re: F6F6Dodge] #607206
02/07/10 10:11 PM
02/07/10 10:11 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
As long as the date preceeds your engine assembly date it would be considered OK. Most parts on an A12 preceed the EAD by 1-4 wks or so. If you do not have the original block, your K- frame will have a date code on it that has proven to be very close to or the same as the EAD on many A12's. Keep in mind that on the A12 cars, the assembly date was not necessarily before the SPD on your fender tag. You've got to look for other clues to the production date...and the K-frame is one, the door panels are also usually within a few days of the actual production date.
Re: A-12 hi-po exhaust manifolds for 3/29 dated car [Re: RoadRunnerJD] #607207
02/07/10 10:47 PM
02/07/10 10:47 PM
Indiana
Indiana
Are these dates cast onto the mainfolds somewhere also???
Re: A-12 hi-po exhaust manifolds for 3/29 dated car [Re: F6F6Dodge] #607208
02/07/10 10:47 PM
02/07/10 10:47 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Those are casting part numbers
Re: A-12 hi-po exhaust manifolds for 3/29 dated car [Re: Dougsmopars] #607209
02/07/10 10:52 PM
02/07/10 10:52 PM
Indiana
Indiana
what do those numbers mean??? the ones I listed are on a pair of manifolds that I am looking at buyimg , but don't want the wrong ones...Thanks
Re: A-12 hi-po exhaust manifolds for 3/29 dated car [Re: F6F6Dodge] #607210
02/07/10 11:23 PM
02/07/10 11:23 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
The part numbers you listed are correct. The casting date codes normally appear on the manifold as well. Generally near the part number.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: A-12 hi-po exhaust manifolds for 3/29 dated car [Re: 70gtx440dana] #607211
02/07/10 11:36 PM
02/07/10 11:36 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
see the date casting on the left *2 19 69* these would probably fall right in line for your car, maybe to early but I need them for my 4/26 A12
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: A-12 hi-po exhaust manifolds for 3/29 dated car [Re: mopargem] #607212
02/08/10 09:11 AM
02/08/10 09:11 AM
Indiana
Indiana
thanks for all your help...basically look for the casting numbers with a date stamp a month or so ahead of the 3/29..correct??
Re: A-12 hi-po exhaust manifolds for 3/29 dated car [Re: F6F6Dodge] #607213
02/08/10 11:33 AM
02/08/10 11:33 AM
Alabama
BigMoneyLewis Offline
Alabama
Yes, but keep in mind , all A12 cars carry an SPD of either 3/29 or 4/26 . The A12 registry should help you nail it down closer based on your sequential number (last 6 digits of your VIN).
Another simular example, all Superbirds carry a B30 (Nov 30 spd, but were built between October and December).
Greg
gregward@mchsi.com phone 256-852-0955
Re: A-12 hi-po exhaust manifolds for 3/29 dated car [Re: F6F6Dodge] #607214
02/08/10 03:17 PM
02/08/10 03:17 PM
Warrenton, VA
Warrenton, VA
Not for an A12! You need to use the engine assembly date stamped on the top pad to the right side of the distributor looking from the front. It's next to the front of the driver's side cylinder head. It is a 2 or 3 digit number such as indicating the month and day the engine was assembled. For example, mine is a 426 SPD on the fender tag but the engine is 6 3. All my original date coded parts preceed 6/3/69 but are mostly dated after 4/26/69. It will be the same on your car. If you do not have the original block, look for the date code in the front of and in the middle of your k frame. That is a close date to when your real production date was. Your date codes should be before that date by 1-4 weeks or sometimes even earlier.
Re: A-12 hi-po exhaust manifolds for 3/29 dated car [Re: RoadRunnerJD] #607215
02/08/10 06:13 PM
02/08/10 06:13 PM
Dougsmopars Offline
Dougsmopars  Offline
If the motor is not orignal who cares about dates on manifolds? Either it's number matching or not. Close enough is only in horseshoes.
Re: A-12 hi-po exhaust manifolds for 3/29 dated car [Re: RoadRunnerJD] #607216
02/08/10 06:57 PM
02/08/10 06:57 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
My 4/26 car has an engine assembly date of 3/19, my exhaust manifolds are dated in february.
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
