Wiper Motor Won't Park (run reverse) on Bench??
#606975
02/07/10 02:05 PM
02/07/10 02:05 PM
Posts: 1,149 NW New Jersey
RSI700VIPER
NW New Jersey
69 B Body 3-speed wiper motor. Darn thing runs great going forward in all three speeds, but doesn't park. Tested switch and was OK. Removed motor and bench tested according to service manual. Jumped brown and green wires, grounded red and put 12V to blue wire so motor should run backwards, but won't?? How can it run forwards OK, then when I switch polarity, it's dead. I'm not a wiring rocket scientist but what's up? Jules...HELP!
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5 1969 Daytona Charger 440 4-Speed, Dana, EV2 1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7 1970 340 Six Pack Callenger T/A 4-speed T8 Tan 1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth 1969 Talladega Torino, 428CJ 1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: Wiper Motor Won't Park (run reverse) on Bench??
[Re: JulesdaWiperman]
#606978
02/07/10 11:42 PM
02/07/10 11:42 PM
RSI700VIPER
NW New Jersey
Jules...Yes, I removed the cover and cleaned the contact points before testing. Is it possible I installed the cover with the cam in the wrong position? Are the points open or closed when the motor runs in reverse before parking? Is there a trick to installing the cover plate? Thanks
#606981
02/08/10 09:22 AM
02/08/10 09:22 AM
RSI700VIPER
NW New Jersey
Thanks for the posts. Pretty sure I didn't install the switch cover correctly now. Will work on cover and continuity tests tonight.
[Re: RSI700VIPER]
#606982
02/08/10 06:58 PM
02/08/10 06:58 PM
RSI700VIPER
NW New Jersey
HAAAA! Jules was right again. Even though the points were clearly closed, the curcuit was open between the gear cover tabs. I cleaned and rebent the contact arm slightly to ensure full bearing on the point surfaces. Now it works like a charm. Thanks all for input.
