Re: RODS HITTING CAM !
[Re: NENE]
#606708
02/07/10 08:40 AM
02/07/10 08:40 AM
Posts: 1,629 pa
572charger
pa
yeah thats the problems with aluminum rods !u need a raised cam block or a set of oliver steel rods my 606 is soooo close with steel olivers 4.750 stroke no raised cam block! or a smaller cam is it a 4.500 stroke? did u degree cam in ??
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: NENE]
#606709
02/07/10 08:56 AM
02/07/10 08:56 AM
Posts: 52,972 Romeo MI
MR_P_BODY
If its just hitting you might go have the cam ground to a smaller base circle EDIT assuming you have the cam in at the right location
[Re: 572charger]
#606710
02/07/10 09:40 AM
02/07/10 09:40 AM
Posts: 99 FRANCE / PARIS
NENE
FRANCE / PARIS
Yes it's a 4.5 stroke with a Bryant crank and Venolia pistons. The rods are hitting just behind the rod bolt hole (at the outside of the hole). The cam is degreed, it is a old Crane with .710" lift (in fact .800 because I have 1.7 rockers) It was ok with my old set of Manley I beam rods, but they are too weak for my +1000 hp now.
'70 Cuda with a 572 Keith Black / B1 heads with a sheetmetal intake (2 dominators) Lencodrive 3 speed trans. 2350 lbs with me
Run 8.04" / 168 mph 1.11" 60 ft
Fastest Mopar at the Euro Mopar Nats
website : http://vantastic-racing.com/
[Re: jamesc]
#606712
02/07/10 10:14 AM
02/07/10 10:14 AM
Posts: 5,067 Orlando Florida
blown572dart
Orlando Florida
i believe it's common practice to relieve the rods where they would hit the cam. obviously this needs to be done properly.
Yeap seen it first hand
[Re: mr2performance]
#606714
02/07/10 11:58 AM
02/07/10 11:58 AM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
4.615 " Bryant crank , Oliver / RBRE rods , and KB block . Clears on my 557" Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: formula S]
#606716
02/07/10 01:22 PM
02/07/10 01:22 PM
Posts: 19,379 Las Vegas
Al_Alguire
Las Vegas
Clearancing an aluminum rod is a pretty common practice in a BB Mopar.
Post deleted by Defbob
#606717
02/07/10 02:11 PM
02/07/10 02:11 PM
#606718
02/07/10 02:14 PM
02/07/10 02:14 PM
Quicktree
[Re: jamesc]
#606723
02/08/10 05:32 PM
02/08/10 05:32 PM
Posts: 1,361 Wild West
M_D
Wild West
With 2.2" journal rods and a 4.5" stroke I have room to spare even for a longer stroke. I doubt you'll have to take much off the rod. Be careful not to nick the rod beams, that would create a stress riser which could possibly cause a rod failure.
[Re: M_D]
#606724
02/08/10 05:38 PM
02/08/10 05:38 PM
The cam has to be degreed before you start grinding rods--Most BME rods are already shaved--at least the ones from Indy are--have the cam in 5-6 degrees off and it won't work--the easiest guage is a piece of wire --you can bend it and get in there to measure easy--get wire diameter you need 060 or whatever.
[Re: NENE]
#606725
02/08/10 09:45 PM
02/08/10 09:45 PM
Posts: 345 Arkansas
JoWeTu_6
Arkansas
Same thing happened 2 me, took a little off 2 rods at bolt hole and that was it. I used GRP 5500 7.10in SERIES rods on my 588cdi (4.50 bore\4.625 stroke) Jowetu_6
