440 Motor mounts HELP!! #606467
02/06/10 09:21 PM
02/06/10 09:21 PM
indiana,usa
donsbelvedere Offline OP
indiana,usa
Hello,
Putting a mild 440 into my 1966 Plymouth Belvedere and was wondering if the Schumacher mounts would be enough to hold with out a torque strap on the motor...thanks Donnie
Re: 440 Motor mounts HELP!! [Re: donsbelvedere] #606468
02/06/10 09:44 PM
02/06/10 09:44 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
stock motor mounts would do the trick for a mild motor. Those will be more then enough.
Re: 440 Motor mounts HELP!! [Re: donsbelvedere] #606469
02/06/10 09:47 PM
02/06/10 09:47 PM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
I highly recommend schumacher's torque strap being used also,helps keep the stress off the motor mount.
Re: 440 Motor mounts HELP!! [Re: donsbelvedere] #606470
02/06/10 11:17 PM
02/06/10 11:17 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Just put a solid mount on the drivers side and leave the rubber one on the pass. side. It won't break and the other side will live forever too unless you race in reverse...
Re: 440 Motor mounts HELP!! [Re: QuickBpBp] #606471
02/07/10 12:28 AM
02/07/10 12:28 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The schumacher mounts work great. I just used a length of chain as my torq strap. And I have that length of chain sinched up tight.
