68 Charger heater box #606317
02/06/10 06:52 PM
02/06/10 06:52 PM
Kansas
monacoman Offline OP
Kansas
Will a non A/C heater box fit into an A/C car? Will there be any difference in the firewall where the heater hoses come through? Thanks for any help.
Re: 68 Charger heater box [Re: monacoman] #606318
02/06/10 07:04 PM
02/06/10 07:04 PM
Middle of the mitten
69DodgeCharger Offline
Yes there is a difference. What we did with my car was weld/graft in a donor piece from a non A/C car into the firewall. The two mounting studs for the non A/C heater box on the passenger side are a direct bolt in. The mounting stud on the drivers side of the heater box is off about a half inch or so. You will see an indent in the firewall, or at least mine had one. Drill your new hole for the mounting stud there and it will bolt right up. I went this route because I had a working non A/C box, but was missing everything for the A/C set up.
Re: 68 Charger heater box [Re: 69DodgeCharger] #606319
02/07/10 12:24 AM
02/07/10 12:24 AM
Kansas
Kansas
OK, Thanks alot.
Re: 68 Charger heater box [Re: monacoman] #606320
02/07/10 09:40 PM
02/07/10 09:40 PM
Kansas
Kansas
Who makes a good heater box rebuild kit?
Re: 68 Charger heater box [Re: monacoman] #606321
02/07/10 10:58 PM
02/07/10 10:58 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
