STUCK pistons ADVICE
#606063
02/06/10 03:11 PM
02/06/10 03:11 PM
Posts: 1,108 Lynch Road
mro
Lynch Road
I've got to break the pistons out of a 383 - Assuming the rings are all stuck - I have no intention of re-using the pistons - would like to save the rods if possible - the caps are off the rods and crank but the crank is stuck because all the pistons are frozen in place - the block is important to the care ( numbers) Any ideas to make this as easy as possible? AND is anyone making 383 pistons 10:1 comprssion .30 over? Thanks!!!!
68 Satellite Wagon and a few other ones
Re: STUCK pistons ADVICE
[Re: mro]
#606065
02/06/10 03:21 PM
02/06/10 03:21 PM
RapidRobert
Put some diesel fuel or kerosene on top of them for several days. Worst case scenerio might have to drill a bunch of holes in each piston top to free up the piston walls. Would be time consuming but with it being a #'s matching block I wouldn't do much pounding on the pistons. When you get it rescued you'll soon forget about all the labor it took but if you crack the block you'll be upset for a long time.
[Re: 6pkaar]
#606067
02/06/10 03:29 PM
02/06/10 03:29 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
1.)Mopar rust penetrant.Soak each cyl several times.It will eventually free up. 2.)A few shots with a dead blow hammer should help. 3.)If 1 or 2 doesn't work if may be neccesary to break the top of the piston.
Leave the gun.......take the Cannoli's....Mike
[Re: AndyF]
#606071
02/06/10 10:28 PM
02/06/10 10:28 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
Just bust them out of there. Use a steel rod up from the crankcase and hit it with a 5lb sledge hammer. Cast pistons will easily bust. You can usually only get a few pistons at a time so you have to work your way around the block. Hopefully you can bust the stuck ones and then rotate the crank enough to get to the next ones.
Big This is what I used last time
[Re: 4BBodies]
#606074
02/07/10 02:48 PM
02/07/10 02:48 PM
Posts: 3,528 Lansing, MI
70gtx440dana
Lansing, MI
Lots of good advice here....I freed up a 440 by using PB blaster rust penetrant, a 5 lb. maul and a stack of hockey pucks taped together to beat on. Cut a hole in small piece of wood just larger than the bore dia. to protect the top of the block in case you miss the hockey pucks. Worked for me and all of the pistons were stuck. Good luck!
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 1970mopar]
#606076
02/07/10 09:00 PM
02/07/10 09:00 PM
Posts: 1,017 Ridley Park, Pa.
69MOPE
super gas
super gas
Ridley Park, Pa.
Take it to your local engine machine shop and have them quote you for the job. I bet they will be able to do it for less $$ than you think and you won't have the issues of possible damage trying to do it yourself .
![](/ubbthreads/images/graemlins/iagree.gif) It's going to the machine shop anyway for the .030 bore!
[Re: @#$%&*!]
#606079
02/09/10 12:26 AM
02/09/10 12:26 AM
Posts: 1,086 Baton Rouge, La.
StandOnIt
Baton Rouge, La.
Diesel fuel works well. I got some out with Kroll penetrating oil also. I agree with lightly sanding the cyl's above the slugs so the will come on out once they are free'd up. A hammer and a piece of wood to work them around in there. Good luck with it and just take your time.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
[Re: 72dak]
#606081
02/09/10 12:27 PM
02/09/10 12:27 PM
Posts: 304 Ohio
LS-300
Ohio
May sound strange but the last one I incountered my Grandfather showed me how to get it out. We went out and got some Dry Ice. Remember handlying with caution. Packed above the piston with it and covered it over with a section of plywood. We made a piece of wood as close to the diameter of the cylinder as we could. After a short with using the wood block we made and a hammer we pounded it down out the bottom of the block. Didn't take much work and didn't damage the block. Shocked the snot out of me but he did this a lot on trucks that he rebuilt.
1979 Chrysler 300
1968 Barracuda project
