Page 2 of 3 1 2 3
Re: A Little Valiant progress **MINI TUB ALMOST DONE** [Re: blown572dart] #605680
02/14/10 12:27 AM
02/14/10 12:27 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Is that seam sealer paintable?
It's bondo to cover my fugly welding skills or lack of
I understand, I'm very good with a grinder .
Re: A Little Valiant progress **MINI TUB ALMOST DONE** [Re: justinp61] #605681
02/14/10 01:15 AM
02/14/10 01:15 AM
Richmond, Tx. (Houston)
GTSDave Online laugh2
Looking Good. Love the wheels!
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: A Little Valiant progress **MINI TUB ALMOST DONE** [Re: blown572dart] #605682
02/14/10 08:38 AM
02/14/10 08:38 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
Jimmy the BONDO Master...
lookin good there Jim..
uh huh!! I found some for you..
Post deleted by Defbob [Re: smokinwoody] #605683
02/14/10 09:40 AM
02/14/10 09:40 AM
Re: A Little Valiant progress **MINI TUB ALMOST DONE** #605684
02/14/10 10:20 AM
02/14/10 10:20 AM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
Looking Good
Switched to the dark side...
Re: A Little Valiant progress **MINI TUB ALMOST DONE** #605685
02/14/10 10:22 AM
02/14/10 10:22 AM
Orlando Florida
blown572dart Offline OP
Orlando Florida
Next time, use seam sealer instead of bondo!
What I mostly wanted to make it smooth like it never happened. seam sealer I don't think will look the same But I am just a dunb AZZ Electrician so could be totaly wrong
Re: A Little Valiant progress **MINI TUB ALMOST DONE** [Re: blown572dart] #605686
02/14/10 10:30 AM
02/14/10 10:30 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
That's what I'm shooting for. My filler pieces are butt welded but it will have seam sealer around the base of the wheel well like it came from the factory.
Re: A Little Valiant progress **MINI TUB ALMOST DONE** [Re: justinp61] #605687
02/14/10 10:52 AM
02/14/10 10:52 AM
Orlando Florida
Orlando Florida
I just don't want it noticeable don't matter to me if it looks factory Surely the Dana and the fuel cell in the trunk will give it away.
Really am thinking about removing the spare tire area and making it all flat but who knows yet.
It sure would make putting the fuel cell easier and clean it up.
Re: A Little Valiant progress **MINI TUB ALMOST DONE** [Re: blown572dart] #605688
02/14/10 10:57 AM
02/14/10 10:57 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Mine's gonna have one to.
Re: A Little Valiant progress **MINI TUB ALMOST DONE** [Re: blown572dart] #605689
02/14/10 01:25 PM
02/14/10 01:25 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Really am thinking about removing the spare tire area and making it all flat but who knows yet...
The void makes a nice 'weather-guard' for the fuel pump. JMHO
Re: A Little Valiant progress **MINI TUB ALMOST DONE** [Re: blown572dart] #605690
02/14/10 01:33 PM
02/14/10 01:33 PM
That is what I did with my Cuda. The spare tire well was so rotten it was a no brainer for me.
-Dave
Re: A Little Valiant progress **MINI TUB ALMOST DONE** [Re: GTSDave] #605691
02/14/10 07:33 PM
02/14/10 07:33 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Deja Vu man !
I also have seam sealer for the bottom......I was wondering if sandable primer in coats would fill that gap over the top of the wheel well.......it is only .032 or so deep.
I got some " splatter " paint that looks very trunk floor like......that is what I will be squirting behind the back seat to hide my shoddy workmanship.
I haven't decided if the back seat will go back in or not yet......I got the cage kit to keep it , but since I don't plan on riding back there , it is low on the priority list.
Nice work so far.
Keep the updates coming.
Re: A Little Valiant progress **MINI TUB ALMOST DONE** [Re: tubtar] #605692
02/14/10 07:56 PM
02/14/10 07:56 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Lookin good
I always wanted one of those lighting rod shifters when I was growing up
Re: A Little Valiant progress **MINI TUB ALMOST DONE** [Re: tubtar] #605693
02/14/10 08:00 PM
02/14/10 08:00 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
The pic HardcoreB has above is my Dart Sport. I also used the spatter paint to hide it all. Came out pretty good.
Re: A Little Valiant progress **MINI TUB ALMOST DONE** [Re: Dartin] #605694
02/14/10 08:04 PM
02/14/10 08:04 PM
Orlando Florida
Orlando Florida
I agree it looks great
Wonder how bed liner would look even though it would probably be just as easy to use trunk splatter.
I bought some rust bullet to spray it all down first,even picked up there black shell. The one side has the rust bullet on the floor pan.
Re: A Little Valiant progress **MINI TUB ALMOST DONE** [Re: blown572dart] #605695
02/14/10 08:15 PM
02/14/10 08:15 PM
Dartin Offline
Dartin  Offline
I thought about that too. It may be more durable around gas and more scratch resistant.
Re: A Little Valiant progress **MINI TUB ALMOST DONE** [Re: Dartin] #605696
02/14/10 09:45 PM
02/14/10 09:45 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
looking good
Re: A Little Valiant progress **MINI TUB ALMOST DONE** [Re: Dartin] #605697
02/14/10 09:54 PM
02/14/10 09:54 PM
north carolina usa
beeson44 Offline
beeson44  Offline
north carolina usa
In regards to filling the patch area, I run a restoration shop and the way we do it is when running the factory inner wheel tube is to cut a piece of sheet metal 1 inch wider than the void left and then flange 1/2 inch on each side of the patch downward.Then we puntch holes every 3 inches in the flanged areas and plug weld each side to the old parts when done you end up with a smooth repair just takes a light skim of mud.Or one my dart I wasn`t worried about factory looks I cut the factory wheel tub 2 inches inside the center seam and then made the inside portion of my tub with sheetmetal formed to fit the shape of the factory outer wheel house i also roll beads for strength, you end up with a 90 degree edge were it turns down towards the rail so theres more tire room.The only problem is moving the trunk spring mounts in were the outher way you can retain the factory mount.On my 1969 dart with fabed inner half of tub I was able to fit 315 60 15 tires with room to spare.Thats the ways we have found work well.
Re: A Little Valiant progress **MINI TUB ALMOST DONE** [Re: beeson44] #605698
02/15/10 07:47 AM
02/15/10 07:47 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I seam sealed the top,frt and inside .The back that you see when you open the trunk I bondo smooth.fro the inside the car I used rustoleum textured paint and inside the wheel well was dupli truck bed spray.I think it looks good I will try to get pics.
Re: A Little Valiant progress **MINI TUB ALMOST DONE** [Re: Scamp408] #605699
02/15/10 07:55 AM
02/15/10 07:55 AM
Arizona
Chris'sBarracuda Offline
Arizona
I bet you could get a full chassis from that Mike Roth guy and just stick the body on it..I'm pretty sure he had one for sale..
Cheap too..
There.. Problems all solved..
Chris..
Page 2 of 3 1 2 3
