Re: Transmission rebuild manual
[Re: cudaboy]
#605643
02/06/10 09:51 AM
02/06/10 09:51 AM
Posts: 178 Tidewater, VA
TMCCuda
Tidewater, VA
It's not hard to do at all. This link has steps 727 rebuildI really like this book because it addresses performance mods. Chrysler Torqueflite I also have an old factory service manual that covers a rebuild. Plenty of Moparts sponsors can help out too.. TCS , A and A , CRT.
1970 Plymouth Barracuda
1994 Ram 1500 4x4 5.2L
2004 Ram 1500 4x4 5.7L Quad Cab
[Re: cudaboy]
#605644
02/06/10 11:34 AM
02/06/10 11:34 AM
RapidRobert
off topic, I'd suggest cleaning the outside case spotless before you start so when going back together you wont bump particles of grit into the trans (trust me on that one). checking the input shaft free play w a dial indicator (record it) before you start and rounding up a pair of long banquet type tables so you can dissassemble the guts out in sections & keep the locations in order such as thrust washers etc facing the right way and the clutch packs in order like an exploded instruction diagram would look then w the trans up on the operating table upside down remove the pan pull the front pump & continue on. take each piece/section to the far end of the table & work backwards so everything is in order. EDIT take notes on which way the thrust washers etc face as in ie "the scored side faces to the rear", "the notches go to the front" etc. 6-8 sentences on a note pad during dissassembly will be a Godsend when going back together and only takes a few seconds of work & interrupting your train of thought to grab the pencil. Most of us think we have a photographic memory but I sure dont
[Re: cudaboy]
#605646
02/07/10 09:29 AM
02/07/10 09:29 AM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
What is the best one? Where can I get one? I want to do my own, it's something I have been planning on doing for years and it's now time.
727's and 904's
thanks
Dennis
Carl Munroe has very detailed book on the subject. This along with the FSM should explain quite a bit.
