primer color under panther pink? #605426
02/05/10 09:40 PM
02/05/10 09:40 PM
Memphis, MO
X
xpsyclonex2002 Offline OP
X
Memphis, MO
I will be painting my car panther pink this summer. What color primer should be used under this? White? Gray? I am sure white would make the pink "pop" but what did the factory use?
Re: primer color under panther pink? [Re: xpsyclonex2002] #605427
02/05/10 10:12 PM
02/05/10 10:12 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
you should use the recommended "shade value" by the paint manufacturer of your choice, if you decide to alter the "base", do a spray out of various tests, on different shade values to see what you desire
Re: primer color under panther pink? [Re: xpsyclonex2002] #605428
02/06/10 02:04 PM
02/06/10 02:04 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
The factory used several different primers with different colors. However the primer that was last used under the color was ruddy red. But with new paints and base coat I woudl use a tintable primer. Color ...... pink
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: primer color under panther pink? [Re: MOPARMIKE69] #605429
02/06/10 03:42 PM
02/06/10 03:42 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Check with your paint supplier. We use Dupont chroma premeir and every color has the correct sealer listed. Wrong sealer will cause color to be off, shading problems and require more coats to cover. I'd check with the paint supplier to see what color sealer is recomended. It doesn't matter what color primer you use on your body work. Car should be sealed before color goes on. Sealer color matters.
Re: primer color under panther pink? [Re: Dougsmopars] #605430
02/06/10 06:09 PM
02/06/10 06:09 PM
Wattsburg, Pa
Dr V Offline
Dr V  Offline
Wattsburg, Pa
The closer the sealer color is........ The better coverage and less base color u will need before clear.
69 1/2 A12 BEE 4 spd
1968 Charger 383
1970 Roadrunner 440+6 Survivor
2019 Redeye
2005 FORD GT Red/White
2017 Viper ACR Extreme Red/White
1979 Branco Red/Red
2018 Porsche GT3 Miami
1971 440+6 Cuda 4 speed V2
2020 Sebring Orange Vette
1979 Chevy Boogie Hippie Van
Re: primer color under panther pink? [Re: Dr V] #605431
02/06/10 06:34 PM
02/06/10 06:34 PM
Dougsmopars Offline
Dougsmopars  Offline
Sometimes. Viper red calls for white sealer. in Dupont. Thats why i say ask your paint supplier.
