what trans speedo gear? #605350
02/05/10 08:12 PM
02/05/10 08:12 PM
imperial mo.
stickman Offline OP
stickman  Offline OP
imperial mo.
Does anyone know what trans gear I should use with 3.55 gears & a 255 60 15 tire? Thanks
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: what trans speedo gear? [Re: stickman] #605351
02/05/10 08:31 PM
02/05/10 08:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You need a 34 tooth pinion.
Re: what trans speedo gear? [Re: John_Kunkel] #605352
02/06/10 10:35 AM
02/06/10 10:35 AM
imperial mo.
stickman Offline OP
stickman  Offline OP
imperial mo.
Thanks john
Re: what trans speedo gear? [Re: stickman] #605353
02/06/10 11:23 AM
02/06/10 11:23 AM
Might put a piece of flat stock on top of one of your rear tires and measure underneath it to ground & see if your actual dia matches what the listed dia for that tire is. Plus if it isn't a whole # it could nudge you one way or the other on your tooth count choice.
Re: what trans speedo gear? [Re: RapidRobert] #605354
02/06/10 12:03 PM
02/06/10 12:03 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: what trans speedo gear? [Re: RapidRobert] #605355
02/06/10 05:10 PM
02/06/10 05:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You never answer my question when I ask "What about the flat spot on the bottom?"
The circumference (or rollout) of the tire is what matters, not the diameter measured with weight on.
Re: what trans speedo gear? [Re: John_Kunkel] #605356
02/06/10 07:22 PM
02/06/10 07:22 PM
JK you're never going to let me live that down & I was thinking you'd let me slide on that after a period of time. So much for me thinking huh . Alright here goes: My reasoning is that my tires are almost perfectly round so the diameter spec in the archives works in my case and when I used the chart w my dia and my ratio it made my odo spot on (checked @ interstate mile markers) and luckily my speedo also was correct (checked by a digital roadside MPH sign and measuring rollout would require a helper to drive the car for a few feet as I watch for the stem to hit 12 0'clock again then tape measure the distance then a bunch of math .
Re: what trans speedo gear? [Re: RapidRobert] #605357
02/06/10 09:16 PM
02/06/10 09:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
OK, if you apply a small slow-drying paint daub on the center of the tread on a rear tire and roll the car forward, the paint daub will make two marks on the ground, measure between them and this is the actual rollout on the tire.
If the tire is 85 inches in circumferance (the rollout) the working diameter will be 27.056". If you use your "lay a stick on top of the tire and measure to the ground" you will likely get a smaller measurement of the diameter than the actual 27" due to that flat spot on the bottom of the tire but the rollout will still be 85" and that's what the odometer needs to see.
If the flat spot is 1/2" your measured diameter will be 26 1/2" which will make the rollout 1 3/4" too short which will result in a 2% error. In the real world you'd be lucky to come within 2% accuracy from one pinion to the next larger/smaller size but the point is the "stick on top" measurement is not the correct diameter for computations especially considering that many tires will have more than 1/2" squat.
Re: what trans speedo gear? [Re: John_Kunkel] #605358
02/06/10 09:25 PM
02/06/10 09:25 PM
Alright, Pi divided into the rollout to get the actual diameter
