Re: HUGE PROBLEM! NEED HELP! [Re: 3ddart] #605345
02/06/10 12:28 PM
02/06/10 12:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Also if the deck was cut a fair bit your locating dowels
might be bottomed out in the heads holding them up
a small amount
Re: HUGE PROBLEM! NEED HELP! [Re: MR_P_BODY] #605346
02/06/10 01:18 PM
02/06/10 01:18 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
All good advice here, I would make a list and go from easy to hard
Re: HUGE PROBLEM! NEED HELP! [Re: emarine01] #605347
02/06/10 03:56 PM
02/06/10 03:56 PM
Central Wi.
1965wedge Offline
1965wedge  Offline
Central Wi.
Is possible the water is coming up around a head-bolt?
Re: HUGE PROBLEM! NEED HELP! [Re: 1965wedge] #605348
02/06/10 07:38 PM
02/06/10 07:38 PM
Louisiana
K
kzinge1 Offline OP
kzinge1  Offline OP
K
Louisiana
The deck was cut .065, which seems like a lot to me. How high does the dowel pin usually go into the head? And how deep is the hole in the head that the pin goes into?
As for water coming up around a head bolt, it could be possible but I don't know yet.
Another possibility is when the machine shop cut .035 out of my chambers in the quench area it could have caused a water leak.
Re: HUGE PROBLEM! NEED HELP! [Re: kzinge1] #605349
02/06/10 07:56 PM
02/06/10 07:56 PM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
Which machine shop did you use and where?
