I am having a nagging misfire on my 94 318 Magnum Ram. On tip-in for acceleration it will misfire and sometimes backfire thru the intake at right around 2100 RPM.
It has new plugs, wires, cap, and rotor. The misfire seems to have killed my MSD 6AL box, so I am running on the stock ignition.
I thought that may be the TPS was giving faulty readings so I changed that, with no improvement.
Around New Years, it lost power and I thought it was the plenum gasket, so I changed that to no avail. The throttle body and intake were cleaned. That power loss turned out to be a broken down catalytic converter clogging the exhaust.
Still the misfire is there. The plugs look good and it idles smooth. I put a timing light on it and at 2000 RPM it looks to be advancing about 30-35 degrees, but it does dance a little bit.
About 60,000 miles ago, I put a Cloyes double roller timing chain on it, so I don't think the chain has jumped.
No codes have been set.
The backfire and bad cat make me think it is running rich...How do I tell? Is there a way to check for a funky injector?
Anybody got any experience on what the SBEC computer is doing?
Any help will really be appreciated...
