Re: Stahl Early A-body Headers
[Re: actionange]
#605054
02/06/10 01:43 PM
02/06/10 01:43 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Call Stahl and talk to Judy......I went through the same dilemma as you.......I decided to go with a new motor with W-9's and an alterKation so I could get headers to fit. There were other compelling reasons too , But I looked into the Stahl headers for it. I believe they are under the car.......or at least not full fenderwell. The odds are that at least one tube will be outside the engine bay just based on how much room is available. There will be some tube cutting maybe , and getting them to fit will be a treat. I had the Hooker's with the 1 5/8 primary on the car and they were an exercise in patience whenever they went on or off. But I am going to use the later A body with 1 7/8 " primaries and they sold me the tubes pre bent and a set of collectors for a great price. I was told that some of the tubes will need to be cut and welded on install for the p/n 303 's. The options are limited for under chassis. TTI makes a set in 1 5/8 to 1 7/8 step headers that looked pretty good......I think one of the torsion bars had to be removed for install. Good luck with it.
[Re: tubtar]
#605060
02/10/10 06:21 PM
02/10/10 06:21 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
You have remove both T-bars to install, but they do fit nice, they also come with custom collectors
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: Overdrive440]
#605061
02/10/10 06:27 PM
02/10/10 06:27 PM
Posts: 1,418 Mcallen, TX
SB449VALIANT
Mcallen, TX
Awesome pictures! thanks! Do you have a couple looking inside the wheel wells?
wow!!!!!super....
[Re: Overdrive440]
#605063
02/10/10 06:53 PM
02/10/10 06:53 PM
SB449VALIANT
Mcallen, TX
1-5/8" - 1-3/4" step headers. Unfortunately, they don't list a set of W5 headers for this year, only 67-up. I might have to start with TTI flanges and build my own by the looks of things.
Same way i did...
