Stahl Early A-body Headers #605052
02/05/10 03:37 PM
02/05/10 03:37 PM
Manitoba, Canada
O
Overdrive440 Offline OP
O
Manitoba, Canada
Has anybody used the Stahl Model #302 64-66 Mopar
1-3/4" headers?
I am wondering if these are full fender well headers or just a couple tubes in the fender well. I would be interested in some photos.
Re: Stahl Early A-body Headers [Re: Overdrive440] #605053
02/06/10 11:34 AM
02/06/10 11:34 AM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
#7 & #8 go into fenderwell.
Model #303 67-76 SB Mopar A-Body Size Price
1-3/4" Assembled
$1315.00
1-7/8" Assembled With adapter flanges $1415.00
This is from the Stahl website
Re: Stahl Early A-body Headers [Re: actionange] #605054
02/06/10 01:43 PM
02/06/10 01:43 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Call Stahl and talk to Judy......I went through the same dilemma as you.......I decided to go with a new motor with W-9's and an alterKation so I could get headers to fit.
There were other compelling reasons too , But I looked into the Stahl headers for it.
I believe they are under the car.......or at least not full fenderwell.
The odds are that at least one tube will be outside the engine bay just based on how much room is available.
There will be some tube cutting maybe , and getting them to fit will be a treat.
I had the Hooker's with the 1 5/8 primary on the car and they were an exercise in patience whenever they went on or off.
But I am going to use the later A body with 1 7/8 " primaries and they sold me the tubes pre bent and a set of collectors for a great price.
I was told that some of the tubes will need to be cut and welded on install for the p/n 303 's.
The options are limited for under chassis.
TTI makes a set in 1 5/8 to 1 7/8 step headers that looked pretty good......I think one of the torsion bars had to be removed for install.
Good luck with it.
Re: Stahl Early A-body Headers [Re: tubtar] #605055
02/06/10 10:59 PM
02/06/10 10:59 PM
Miami Valley, Ohio
blumaxsavoy Offline
blumaxsavoy  Offline
Miami Valley, Ohio
Bought a set of the #302 Stahl tubes for my son's 65valiant 100 sedan. 416 inch W/ indybrocks. #7 & 8 tubes go through fenderwell, the rest are under chassis W/ slide on collector. Nicest set of headers Ive seen for the application. Be prepared they are VERY pricey, but the qualty is unsurpassed.
Re: Stahl Early A-body Headers [Re: blumaxsavoy] #605056
02/07/10 02:19 AM
02/07/10 02:19 AM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
Re: Stahl Early A-body Headers [Re: tubtar] #605057
02/07/10 02:58 PM
02/07/10 02:58 PM
Manitoba, Canada
O
O
Manitoba, Canada
Whatever I buy will have to be modified, unless I build my own, as I am using W5 heads in a 65 Valiant. I'd want 1-7/8" tubes preferably. I might not be opposed to one tube in the fender well. How much room does that one tube take in there?
Re: Stahl Early A-body Headers [Re: Overdrive440] #605058
02/09/10 08:37 PM
02/09/10 08:37 PM
Miami Valley, Ohio
blumaxsavoy Offline
blumaxsavoy  Offline
Miami Valley, Ohio
Sorry it took so long, here are some pictures of Stahl #302 headers on a 65 valiant. Hope they help.
Re: Stahl Early A-body Headers [Re: blumaxsavoy] #605059
02/09/10 11:57 PM
02/09/10 11:57 PM
Manitoba, Canada
O
O
Manitoba, Canada
Awesome pictures! thanks! Do you have a couple looking inside the wheel wells?
Re: Stahl Early A-body Headers [Re: tubtar] #605060
02/10/10 06:21 PM
02/10/10 06:21 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
Good luck with it.
You have remove both T-bars to install, but they do fit nice, they also come with custom collectors
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: Stahl Early A-body Headers [Re: Overdrive440] #605061
02/10/10 06:27 PM
02/10/10 06:27 PM
Mcallen, TX
Mcallen, TX
wow!!!!!super....
Re: Stahl Early A-body Headers [Re: 65signet] #605062
02/10/10 06:32 PM
02/10/10 06:32 PM
Manitoba, Canada
O
O
Manitoba, Canada
1-5/8" - 1-3/4" step headers. Unfortunately, they don't list a set of W5 headers for this year, only 67-up. I might have to start with TTI flanges and build my own by the looks of things.
Re: Stahl Early A-body Headers [Re: Overdrive440] #605063
02/10/10 06:53 PM
02/10/10 06:53 PM
Mcallen, TX
Mcallen, TX
Same way i did...
Re: Stahl Early A-body Headers [Re: SB449VALIANT] #605064
02/10/10 06:54 PM
02/10/10 06:54 PM
Mcallen, TX
Mcallen, TX
tti w5 flanges
Re: Stahl Early A-body Headers [Re: SB449VALIANT] #605065
02/10/10 06:56 PM
02/10/10 06:56 PM
Mcallen, TX
Mcallen, TX
1 7/8 tubes
Re: Stahl Early A-body Headers [Re: SB449VALIANT] #605066
02/10/10 06:57 PM
02/10/10 06:57 PM
Mcallen, TX
Mcallen, TX
more
Re: Stahl Early A-body Headers [Re: SB449VALIANT] #605067
02/10/10 06:59 PM
02/10/10 06:59 PM
Mcallen, TX
Mcallen, TX
2
Re: Stahl Early A-body Headers [Re: SB449VALIANT] #605068
02/10/10 07:00 PM
02/10/10 07:00 PM
Mcallen, TX
Mcallen, TX
3
Re: Stahl Early A-body Headers [Re: SB449VALIANT] #605069
02/10/10 07:03 PM
02/10/10 07:03 PM
Mcallen, TX
Mcallen, TX
Re: Stahl Early A-body Headers [Re: SB449VALIANT] #605070
02/10/10 07:04 PM
02/10/10 07:04 PM
Mcallen, TX
Mcallen, TX
Re: Stahl Early A-body Headers [Re: SB449VALIANT] #605071
02/10/10 07:09 PM
02/10/10 07:09 PM
Mcallen, TX
Mcallen, TX
Last please dont be mad at me, i know this is not my post, iam just trying to help a little here, on the other hand if Stahl headers would custom bulid 2 inch headers for those using tubular susp. i will placing an order in a hartbeat, thatīs a pretty nice work of art, you got there....
Re: Stahl Early A-body Headers [Re: Overdrive440] #605072
02/11/10 12:09 AM
02/11/10 12:09 AM
Miami Valley, Ohio
blumaxsavoy Offline
blumaxsavoy  Offline
Miami Valley, Ohio
Thanks for the kind words. Actually,our # 7&8 tubes are both like SB449's #8;they both are straight off the port and down. Ill see if I can get a couple of pics. I had one of my boy's do the last ones cause I dont have a clue LOL.This is my 20 year old's 1st project and my 23 YO is building a 63 savoy NSSer. I get confused on what Im working sometimes.
PS; hey billyjay if you see this -remember the white 65? Tom
Re: Stahl Early A-body Headers [Re: blumaxsavoy] #605073
02/12/10 02:16 PM
02/12/10 02:16 PM
Manitoba, Canada
O
O
Manitoba, Canada
Reason I ask is I'm trying to build my car for street and auto-x duty, and full fenderwells are no good for this, and I might be able to get away with one tube in the wheel well. If not, I might have to sacrifice a little bit of flow and run smaller full underchassis headers modified with a W5 flange or something. All options point to fabrication by me to make things fit, but that's not a huge deal.
