Do I need an Ignition box? #604947
02/05/10 01:39 PM
02/05/10 01:39 PM
Fort Wayne,Indiana 46845
mopar 394 Offline OP
I have a Mallory Unilite distributor I am putting in a 440 motor. Do I need to use a Hyfire 6A control box with this distributor or can I use a stock orange control module. I would rather keep it looking stock but don't want to give up to much performance. Thanks
Re: Do I need an Ignition box? [Re: mopar 394] #604948
02/05/10 03:46 PM
02/05/10 03:46 PM
The dist just triggers the ECU and I've used an HEI module (stock and aftermarket) & works fine triggered by our dizzys so I would hazard a guess that you'll be OK and if you have not yet purchased an ECU I would highly suggest something other than an orange box. There are much more reliable options out there to choose from.
