Laser temp readers for A/F reading cyl by cyl? #604729
02/05/10 10:27 AM
02/05/10 10:27 AM
...gently down the stream
LAR_414 Offline OP
LAR_414  Offline OP
Anybody ever use one of those hand held laser temperature tools to read each tube on headers to see if the air fuel mix is off between cylinders. Maybe a way to try out different damns and such on an intake manifold to get a more evened out temp reading from tube to tube. Harbor Freight has a pretty inexpensive one for like $30 on sale right now.
I was thinking then you could just hold the motor at a certain rpm to heat the headers up and then take some temp readings to see how the fuel is being drawn between cylinders.
Re: Laser temp readers for A/F reading cyl by cyl? [Re: LAR_414] #604730
02/05/10 11:05 AM
02/05/10 11:05 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I've ever only used it to find a dead hole.
Not sure how accurate it would be.
Re: Laser temp readers for A/F reading cyl by cyl? [Re: WILD BILL] #604731
02/05/10 11:54 AM
02/05/10 11:54 AM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
I don't think it is very accurate especially if the headers are coated or there is a variance in thickness of the flange or header tubing at all. I tried it on my coated headers and I can get a 100+ degree temp swing just by moving the laser a couple inches on the tube or flange.
Better probably as Bill stated for a dead cyl.
just my
Re: Laser temp readers for A/F reading cyl by cyl? [Re: RonP] #604732
02/05/10 12:05 PM
02/05/10 12:05 PM
NC
DCM71cuda Offline
DCM71cuda  Offline
NC
One thing people don't always realize with IR temperature readers. You actually read a much larger area than just the 'dot'. The cheaper ones will have something like a 6:1 or 8:1 ratio. Meaning that if you are six inches away from your target, you are actually measuring the average temp in a 1" cirlce, not just on the red dot.
Re: Laser temp readers for A/F reading cyl by cyl? [Re: DCM71cuda] #604733
02/05/10 12:11 PM
02/05/10 12:11 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
I did not know that
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Laser temp readers for A/F reading cyl by cyl? [Re: DCM71cuda] #604734
02/05/10 12:16 PM
02/05/10 12:16 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
good point. I think mine is 1/2 area or less. I need to look now that I think about it as it was an expensive one. With that, I still get the variance because that header coating isn't the same thickness when it is sprayed either.
Re: Laser temp readers for A/F reading cyl by cyl? [Re: RonP] #604735
02/05/10 12:32 PM
02/05/10 12:32 PM
LAR_414 Offline OP
LAR_414  Offline OP
I'm just wondering if it's worth it to try and get somewhat close. I've never tried it, so I have zero experience on this.
What kind of temps or temp range do you usually see? Maybe it's good if you see one or two cylinders that are running 100's of degrees hotter than others, meaning they are lean.
I've got my LM-1 and it's reading each side of the exahust. So I'm seeing an average of 4 cylinders. Sure would be nice to tune this cross ram a little better if I know one or two cylinders are really getting robbed, by the others.
Re: Laser temp readers for A/F reading cyl by cyl? [Re: LAR_414] #604736
02/05/10 12:57 PM
02/05/10 12:57 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I have been takin IR readings from just after the build, if ya fool with it enough you will see patterns in your tune
Re: Laser temp readers for A/F reading cyl by cyl? [Re: emarine01] #604737
02/05/10 02:00 PM
02/05/10 02:00 PM
hooziewhatsit Offline
you also need to look at the max temp the gun will read. My cheapo one doesn't go over 450*F. Good for finding a dead hole, but not much else.
Re: Laser temp readers for A/F reading cyl by cyl? [Re: LAR_414] #604738
02/05/10 02:44 PM
02/05/10 02:44 PM
AndyF Offline
AndyF  Offline
It works fine, I use a temp gun all the time for tuning and dyno work. Point it at the oil pan, radiator, block, headers, intake, valve covers, etc.
The key is to have the right kind of finish on the parts. Flat black is the best finish for measuring temps. Chrome or anything shiny is the worst.
Re: Laser temp readers for A/F reading cyl by cyl? [Re: AndyF] #604739
02/05/10 04:06 PM
02/05/10 04:06 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
andy's right about the finish. i have a very expensive IR t/meter but on my headers it reads nothing like the pyro's. it's better for reading slick temps & oil pans as previously suggested.
Re: Laser temp readers for A/F reading cyl by cyl? [Re: LAR_414] #604740
02/05/10 05:21 PM
02/05/10 05:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
To many variables to use a IC to measure the A/F ratio
with any where near accurate readings... a few thousandths
thicker coating on the header will give you 30*
different reading, add in the center cylinder tend
to run hotter.... just use a A/F meter or invest in
EGTs, I have both but now days use the EGTs (on all
8 cyl exactly 1" from the head surface) to set the
flow on the intakes I make and the A/F for its job
Re: Laser temp readers for A/F reading cyl by cyl? [Re: MR_P_BODY] #604741
02/05/10 07:53 PM
02/05/10 07:53 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
Say a cylinder or two are lean or rich, how would you fix that?
Re: Laser temp readers for A/F reading cyl by cyl? [Re: 70blackfish] #604742
02/05/10 07:59 PM
02/05/10 07:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Either try jetting that corner up or work on those
ports on the intake
