Re: Laser temp readers for A/F reading cyl by cyl?
[Re: LAR_414]
#604730
02/05/10 11:05 AM
02/05/10 11:05 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I've ever only used it to find a dead hole. ![](/ubbthreads/images/graemlins/shruggy.gif)
Not sure how accurate it would be.
[Re: WILD BILL]
#604731
02/05/10 11:54 AM
02/05/10 11:54 AM
Posts: 1,633 Jacksonville, NC
RonP
Jacksonville, NC
I don't think it is very accurate especially if the headers are coated or there is a variance in thickness of the flange or header tubing at all. I tried it on my coated headers and I can get a 100+ degree temp swing just by moving the laser a couple inches on the tube or flange. Better probably as Bill stated for a dead cyl. just my ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: DCM71cuda]
#604734
02/05/10 12:16 PM
02/05/10 12:16 PM
RonP
Jacksonville, NC
One thing people don't always realize with IR temperature readers. You actually read a much larger area than just the 'dot'. The cheaper ones will have something like a 6:1 or 8:1 ratio. Meaning that if you are six inches away from your target, you are actually measuring the average temp in a 1" cirlce, not just on the red dot.
good point. I think mine is 1/2 area or less. I need to look now that I think about it as it was an expensive one. With that, I still get the variance because that header coating isn't the same thickness when it is sprayed either.
[Re: emarine01]
#604737
02/05/10 02:00 PM
02/05/10 02:00 PM
Posts: 3,905 Oregon
hooziewhatsit
you also need to look at the max temp the gun will read. My cheapo one doesn't go over 450*F. Good for finding a dead hole, but not much else.
[Re: LAR_414]
#604740
02/05/10 05:21 PM
02/05/10 05:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
To many variables to use a IC to measure the A/F ratio with any where near accurate readings... a few thousandths thicker coating on the header will give you 30* different reading, add in the center cylinder tend to run hotter.... just use a A/F meter or invest in EGTs, I have both but now days use the EGTs (on all 8 cyl exactly 1" from the head surface) to set the flow on the intakes I make and the A/F for its job ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 70blackfish]
#604742
02/05/10 07:59 PM
02/05/10 07:59 PM
MR_P_BODY
Say a cylinder or two are lean or rich, how would you fix that?
Either try jetting that corner up or work on those ports on the intake ![](/ubbthreads/images/graemlins/wave.gif)
