Anyone used a Rotisserie?
#604563
02/05/10 01:21 AM
02/05/10 01:21 AM
Posts: 6,149 Melbourne , Australia
LA360
I am looking at fabricating a rotisserie to stick my car onto to do the underside etc.
Just curious as to what peoples experience is with these, anything to be aware of when setting up a body on it etc?
Thanks AL....
Alan Jones
Re: Anyone used a Rotisserie?
[Re: minivan]
#604567
02/05/10 10:55 AM
02/05/10 10:55 AM
Posts: 4,046 Minnesota
72blubird
Minnesota
You will love it once it is set up. Reccommend cross bracing if doing any serious panel or roof replacement. Sure is nice to do body work in a comfortable position.
What was I thinking....
[Re: 68jim]
#604569
02/05/10 03:30 PM
02/05/10 03:30 PM
Posts: 3,968 North Riverside IL & Lowell IN
GTXKen
super gas
super gas
I built one for my project as well. I found and modified the free plans off the internet.
Mine looks so much like Jim's above in so much that I even had a b-body on it. Every time this comes up there are about 10 sets of plans posted that are largely variations of the same basic plan. do a search and look at all the plans and decide which features you need. Its relatively cheap and easy to build your own. As a bonus you will find all kinds of people who will tell you you need to buy one, they are full of ...beans (after they have been eaten and discharged)
Ken
[Re: GTXKen]
#604570
02/05/10 05:03 PM
02/05/10 05:03 PM
LA360
When the body is rotated 90 degrees, what kind of distance should I have between the side of the body and the base of the frame? Thanks for the replies thus far! AL....
Alan Jones
[Re: LA360]
#604572
02/05/10 08:13 PM
02/05/10 08:13 PM
Posts: 1,029 Southeast Virginia
68jim
Southeast Virginia
I agree as well, as little as possible. I had to reverse a set of mini-tubs on my car and the rottiserie made it soooo much easier. My welding is decent enough but overhead welding is not my best. Rotating the body just to do some basic bodywork and sanding is also much easier standing up. My knees don't work the way they used to...
[Re: 68jim]
#604573
02/05/10 08:47 PM
02/05/10 08:47 PM
Posts: 3,623 Millinocket, Maine
JonC
Millinocket, Maine
Why do you have the casters covered with rags???
[Re: JonC]
#604574
02/05/10 09:12 PM
02/05/10 09:12 PM
68jim
Southeast Virginia
I took those pictures before I started to sand blast the bottom of the car. I used scaffolding casters because they had a larger wheel diameter to make rolling it around easier. The towels were wrapped around them to try and keep the sand out.
[Re: 68jim]
#604575
02/05/10 09:16 PM
02/05/10 09:16 PM
340dart4spd
Parts Problem
Parts Problem
[Re: gtx6970]
#604579
02/06/10 10:41 AM
02/06/10 10:41 AM
Challenger 1
Cincinnati, Ohio
it like putting the drivetrain in from the bottom versus years of 'in from the top'.
Once you've done one on a rotisserie, you'll never go back to doing the same work laying on your back.
I bought used whirley-jig abut 3 years ago for $800 and never looked back
Exactly...
