440 questions....
#60422
05/20/08 06:43 PM
05/20/08 06:43 PM
Posts: 1,143 Imlay City, MI
DTT
super gas
super gas
Imlay City, MI
I recently bought a 440 for a project car. It is already .030 over and overall looks pretty good. Upon putting it on the stand, Ive come across a few questions....
First, I noticed the left side, just below the starter hole a non threaded boss for a bolt to go through for the bellhousing is chipped. Will this be an issue? Can/Should I fix it?? See attached picture....
1978 Pro Street D100
1936 Dodge truck (Hot rod)
1957 Plymouth Plaza
1962 Chrysler 300
1964 Dodge 440
1995 Jeep Grand Cherokee
1971 Big Block Demon (Dads)
Re: 440 questions....
[Re: DTT]
#60423
05/20/08 06:46 PM
05/20/08 06:46 PM
DTT
super gas
super gas
Imlay City, MI
Second question I have regards the pistons. They all have these two small notches facing forward. Im not sure if its just the forward notation mark or??? Heres a picture.....
1957 Plymouth Plaza
1962 Chrysler 300
1964 Dodge 440
[Re: DTT]
#60424
05/20/08 09:34 PM
05/20/08 09:34 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
ahhh , ya , thats going to be an issue , theres a bolt that holds the bellhousing to the engine and judging by its size , 7/16 hardware , its needed ?
the dots probably are to tell you where the front is.
how deep in the hole is that piston ?
[Re: JohnRR]
#60425
05/20/08 10:05 PM
05/20/08 10:05 PM
DTT
super gas
super gas
Imlay City, MI
Is there an easy way I can fix that?? Im not sure how deep the piston is. Thats not at TDC by the way...its just the first one I saw when I uncovered it...Im really hoping to be able to use this engine. The engine I was originally going to use had a motor mount ear busted off, and I didnt discover that until after I had it machined....now this!!
1957 Plymouth Plaza
1962 Chrysler 300
1964 Dodge 440
[Re: DTT]
#60426
05/20/08 10:08 PM
05/20/08 10:08 PM
JohnRR
fix for this and the other is to weld a piece on.
[Re: JohnRR]
#60427
05/21/08 12:22 AM
05/21/08 12:22 AM
DaytonaTurbo
Manitoba, Canada
And if you can't do it yourself, your machine shop should be able to no problem.
ROFL I hope not. Or else you'd be measuring your depth with a yard stick! ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: z1bigtom]
#60432
05/22/08 05:43 PM
05/22/08 05:43 PM
DTT
super gas
super gas
Imlay City, MI
Mine is half there still. I just wasnt sure since it was cast if I needed to use a piece of cast?? Can I just use a piece of steel round stock?I was told you can TIG cast if you use pure nickel rod...This true??
1957 Plymouth Plaza
1962 Chrysler 300
1964 Dodge 440
