Cast Iron or Alum. 6 pack intake #604168
02/04/10 09:03 PM
02/04/10 09:03 PM
California
Don Little Offline OP
California
My 440-6 motor for my Cuda was assembeled on Jan 5 1970. When I bought the car in 1988 it had a aluminum intake. Was that the correct origional?
Re: Cast Iron or Alum. 6 pack intake [Re: Don Little] #604169
02/04/10 09:07 PM
02/04/10 09:07 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
At that point, I would think all 6 pack cars had iron intakes. My recollection was that the aluminum ones were phased out by the latter part of Oct or early November.
MB
Re: Cast Iron or Alum. 6 pack intake [Re: HPMike] #604170
02/04/10 11:16 PM
02/04/10 11:16 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
There more opinions on this subject than there are people on Moparts I have heard of a few that were put on into 70. There are a few guys on here that know more than I do for sure. My Superbird was assembled on Nov 30 and it is a cast iron piece. I think Chrysler may have slipping in a few just to help out the stock and super stock guys. By the way, I assume you are the Don Little of Stocker Fame? If so, welcome to the board. I figured you know more about these cars than most of us will ever will.
Re: Cast Iron or Alum. 6 pack intake [Re: fastmark] #604171
02/05/10 09:48 AM
02/05/10 09:48 AM
Southern Michigan
Dartman440 Offline
Dartman440  Offline
Southern Michigan
I have owned quite a few original 70 Six Pak Cars and the earliest I have owned was a F8 Challenger R/T Sept 13th build date. It had a cast iorn intake. The cast date on the intake was July 27 69. I also had a 70 Six Pak Cuda Built at the LA plant on Oct 69. Red On Red. It was cast iorn too. It is on Ebay right now. You know talking to Al Nichols who is since departed us he was Chryslers carb engineer and tuning guru. RIP Al. He told me that on the 69 1/2 cars. Edelbrock and Holley could not make enough Intakes and carbs. I have TCB Bulletins stating that Holley was rushing these out so fast that the metering block air passages were not drilled all the way thru thus cars not idling and hard starts. If you want My Honest Opinion with all my experience parting out a zillion of these cars dating back to 1976 and owning a ton of these cars back then and had the pleasure of dealing with a lot of Chrysler inside guys over these years. BOB McCurry,Gerry Blake, Al Nichols, Dean Nicopolis, And so on. I would have to say no. They were ready to go into the 70 production year full tilt ahead. The Huber foundry worked all summer long. A lot of guys put these on when they were only around $80.00 that were serious racers to save weight over the cast iorn. The pic is a FC7 Shaker 4 speed 100% Survivor Taken back in the day.
Re: Cast Iron or Alum. 6 pack intake [Re: Dartman440] #604172
02/05/10 10:28 AM
02/05/10 10:28 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
That's my buddy Steve's former six pack 'Cuda and yes, it was/is a true Survivor....
Troy
Troy
Houston Mopar Connection Club
Re: Cast Iron or Alum. 6 pack intake [Re: HPMike] #604173
02/05/10 10:35 AM
02/05/10 10:35 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
MB
....cast Iron,... even most early build cars would have been cast iron, as Chrysler knew it had to ramp up it's own production of the manifold due to Edelbrock's inability to supply the necessary volume perdicted,....exception to the rule would be 1970 Superbird
Mike
Re: Cast Iron or Alum. 6 pack intake [Re: DAYCLONA] #604174
02/05/10 10:41 AM
02/05/10 10:41 AM
cataclysm80 Offline
cataclysm80  Offline
& the 1970 trans am cars. Trans am 6 packs were aluminum (small block).
Tav
Re: Cast Iron or Alum. 6 pack intake [Re: cataclysm80] #604175
02/06/10 03:30 PM
02/06/10 03:30 PM
California
California
Thanks for the info. Your telling me what I expected all along. I guess I'm looking for a iron intake cast in late 1969. Thanks to Dartman for the photo...my car is now FC7 again. It was yellow when raced in NHRA stock class.
Re: Cast Iron or Alum. 6 pack intake [Re: Don Little] #604176
02/06/10 03:52 PM
02/06/10 03:52 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Hi Don,I sent you a PM
Re: Cast Iron or Alum. 6 pack intake [Re: ScottSmith_Harms] #604177
02/06/10 11:32 PM
02/06/10 11:32 PM
USA
rftroy Offline
rftroy  Offline
USA
I bought my 440 6PAK Roadrunner in May of 1975. Scheduled build date was 12/9/1969; date first sold was 12/23/1969. Nice Christmas present, huh?
Now, a lot can happen in 5 years, but it had an aluminum manifold, with the Chrysler part number, and the manifold was painted the same orange color as the engine.
Until someone comes up with proof otherwise, the aluminum manifold stays on.
Bob
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: Cast Iron or Alum. 6 pack intake [Re: rftroy] #604178
02/07/10 12:14 AM
02/07/10 12:14 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
Years ago I had heard that there was a problem with casting porosity on a batch of iron 6bbl manifolds. It appears this affected some (not all) cars built early-November to early-December. Right when the bulk of the Superbirds were being assembled. Aluminium manifolds were used to keep the engine assembly line moving.
My former C02 (12/2/69) Fury GT has an iron manifold. (it was built about 2 weeks later)
rftroy, What plant was your RR assembled at? I'd bet Lynch Rd.
Re: Cast Iron or Alum. 6 pack intake [Re: rftroy] #604179
02/07/10 10:55 AM
02/07/10 10:55 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I used to own both a 1970 six pack runner back in the early 80's, and it had an aluminum manifold. Thankfully,,,,as I think I had to r+r that thing like a hundred trimes for carb issues.but thats another story
Although the car is still semi-local I haven't seen it in years. so no idea on a SBD
Re: Cast Iron or Alum. 6 pack intake [Re: 6bblgt] #604180
02/07/10 12:19 PM
02/07/10 12:19 PM
cataclysm80 Offline
cataclysm80  Offline
I'd bet Lynch Road also.
I'm definitely an E body guy, and I've got a lot to learn about B bodies before I do my own 70 roadrunner, so please correct me if I'm wrong...
The E bodes were all built at either Hamtramck or LA plants.
Weren't all the 69 1/2 A12 cars built at Lynch Road? Which means that the Edelbrock aluminum manifolds would be at Lynch Road. Edelbrock was having trouble making enough aluminum manifolds for 69 1/2 production, which is why Chrysler had to make the cast iron ones. With Edelbrock having problems keeping up, isn't it likely that at least one shipment of aluminum intakes arrived at the Lynch Road plant after 69 production came to a stop in July?
But those aluminum intakes wouldn't have arrived at the wrong plant. If the aluminum intakes were only used at Lynch Road, then leftover aluminum intakes would only be on Lynch Road cars right? No point in shipping leftover parts to a different plant when you can use them right where they're at. Especially if you've got a new supply of Iron intakes you can send to the other plants.
So then, Wouldn't all of this boil down to No Challengers or Barracudas built with aluminum intakes?
What do you guys think?
Has anyone seen a 440-6 E body that appeared to have an original aluminum intake?
Tav
Re: Cast Iron or Alum. 6 pack intake [Re: cataclysm80] #604181
02/21/10 12:53 AM
02/21/10 12:53 AM
Southern Michigan
Dartman440 Offline
Dartman440  Offline
Southern Michigan
I have one of my Early complete 440 6 Intakes. It has a cast date of 7/31/69. It is Cast Iorn.
Re: Cast Iron or Alum. 6 pack intake [Re: Dartman440] #604182
02/21/10 01:03 AM
02/21/10 01:03 AM
Northern Indiana
mr_belvedere Offline
super gas
super gas
Northern Indiana
Can anyone shed any light as to why two different (at least the casting # is different) cast iron 6 barrel intakes were made?
Sorry, dont have the #s in front of me, but I seem to recall the #s were sequential. One ending with 5 and another with 6.
Re: Cast Iron or Alum. 6 pack intake [Re: Don Little] #604183
02/21/10 02:14 PM
02/21/10 02:14 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Too bad there seems to be no documentation of '70 aluminum intakes. I can see doubt that some '70 cars came with Edelbrocks if the motor had been modified over the years. But what about original untouched and unmodified motors? Why change intakes and modify nothing else on the motor?
My '70 Cuda with an A12 SPD has an aluminum intake. I bought it from the original owner in '89. It was 46,000 mile car with an unmodified untouched motor. I noticed the Eldebrock intake and asked about "the aluminum intake", he said it was cast iron. He never knew it was aluminum. Everything he had known about the '70 440-6 was it came with an iron intake and he thought the one on his car was iron cast by Edlebrock!
I know of a '70 RR with an aluminum intake, also with an unmodified untouched motor and a one owner car till '87. SPD was about a week before my Cuda.
There is a Moparts member that has a Cuda with a SPD a few months into '70 that was aluminum equipped.
How or when did a 440-6 motor get the aluminum intake?. My guess is hit or miss, and it was mostly miss. My '70 Super Bee with a SPD of 930 came with an iron intake.
Re: Cast Iron or Alum. 6 pack intake [Re: cataclysm80] #604184
02/21/10 02:27 PM
02/21/10 02:27 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
As far as certain assembly plants using Eldebrocks, it wouldn't matter. Aren't motors are assembled elsewhere?
I have heard the pin hole problem theory before, also two other speculations, surplus intakes being used up and low supply of iron intakes (there were a lot of Six Pack motors being built in Aug-Nov '69).
I don't think the issue is if they were used, it's how to prove which cars got them. This of course is most likely impossible.
Re: Cast Iron or Alum. 6 pack intake [Re: mr_belvedere] #604185
02/21/10 03:11 PM
02/21/10 03:11 PM
Pittsburgh, PA
Deuces-Wild Offline
Deuces-Wild  Offline
Pittsburgh, PA
The cast numbers for 440-6 are 2946275 and 2946276. Both are cast iron. 275 was early model year builds and 276 was late model builds during '70. I wish I knew the reason for the change...
Also, my understanding is that it was A12 cars that used the Edelbrock Al. intakes in '69-'70 which had the cast number 3412046. But... only death and taxes are certain
Re: Cast Iron or Alum. 6 pack intake [Re: Deuces-Wild] #604186
02/21/10 07:30 PM
02/21/10 07:30 PM
grand rapids mi. usa
P
Purestocker Offline
Purestocker  Offline
P
The engine in my 70 Cuda was built in mid December and received the aluminum manifold, again WHO KNOWS..
Re: Cast Iron or Alum. 6 pack intake [Re: Don Little] #604187
02/21/10 08:10 PM
02/21/10 08:10 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I remember seeing it out at Harry's shop still wearing original paint...
