Post deleted by Defbob
[Re: MattW]
#603819
02/04/10 05:27 PM
02/04/10 05:27 PM
Re: Aluminum Rod ???
#603821
02/04/10 10:59 PM
02/04/10 10:59 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
R&R makes a very nice more budget friendly aluminum rod. Have them in a couple of customers cars and they are holding up fine so far.
[Re: MattW]
#603823
02/05/10 05:57 PM
02/05/10 05:57 PM
Thanks for the info Will it survive with a honda journal and how much more do I need to clearance the bottom of the block? Matt
you will do a lot more grinding for clearance with the aluminum rod. i'm curious as to why you "want" to run them in a street combo. there's not that much difference in the weight that it's going to make a real performance difference for a street cruiser. please explain.
#603824
02/05/10 08:29 PM
02/05/10 08:29 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I know about grinding more just want to know how much. RE: PHOTO'S Don't know where you got street cruiser it will probably see more track. Yes there is not much more difference in weight but every little bite helps, plus you have a greater chance of the block surviving if something goes terrible wrong. Matt
#603825
02/06/10 12:10 AM
02/06/10 12:10 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I don't mean to speak for him.....but I have some experience in these matters. Not in running aluminum rods. But in doing things that make no sense. It just sounds cool. Back in the day , there was some guys who ran a local service station..one of them had a small block with aluminum rods and a roller cam in his street car. The impression that made on me as a kid was downright corrupting. The reliability issues that aluminum rods are alleged to have are myths , but if someone claims to have alloy innards on the street , they are viewed by many as a serious player. Sometimes they are. Usually not. Same for a solid roller cam. Not many running down the strasse. The " only kid on the block who has one " thing is powerful. Not to mention expensive.
[Re: tubtar]
#603826
02/06/10 09:22 AM
02/06/10 09:22 AM
MattW
Ontario Canada
???????????????? Now back to the subject, Anyone have photo's of aluminum Rods, in an R3. Matt
[Re: MattW]
#603830
02/06/10 08:59 PM
02/06/10 08:59 PM
Posts: 1,051 The Great White North
RAMM
What is your final cubic inch going to be? What kind of compression do you have in mind? I would think that a Honda journal diameter will hold up just fine BTW. You should come and see me @ the shop. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: RAMM]
#603831
02/06/10 09:06 PM
02/06/10 09:06 PM
MattW
Ontario Canada
Hey Jesse, How the hell have you been?!!!!! Well the CID will be around 430 if my math is correct. I will be down next tuesday is that a good day for you? Matt
[Re: RAMM]
#603832
02/06/10 09:09 PM
02/06/10 09:09 PM
Posts: 2,524 PA
moparacer
PA
I got 6 6.123 small block aluminum rods left from an engine I had with them in years ago.... Dont ask where the other two are...... Ha!
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: RAMM]
#603833
02/06/10 09:15 PM
02/06/10 09:15 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
Not trying to here but, steel rods are showing up in many N/A applications, including "THE" N/A application. And with that much stroke, there will be some compromise in crankshaft strenght with small journals. Altough 7000rpm is modest by today's standards so it probably won't be that big an issue.
[Re: jim sciortino]
#603834
02/07/10 05:09 PM
02/07/10 05:09 PM
Posts: 1,314 Charlotte, NC
LSP
Charlotte, NC
There is only 1 guy left running aluminum rods in "THE N/A application" that I know of. Not so much that the rod is steel, but what it allows you to do to the piston & pin.
