Is this combination 93-octane friendly??? #603778
02/04/10 04:21 PM
02/04/10 04:21 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
NOTE: This post picks up where my "C.R. / Quench / Cranking Pressure dilema" threads leaves off.
Let's talk real-world exprience and whether the following combination will be able to run on 93-octane fuel. I'm basing a purchase decision on it and have some concerns.
RB Short block:
4.360" x 3.75" --> 448 c.i.
Flat-top pistons at zero deck height
Heads:
Edelbrock Victor (heart-shaped chamber)
.040" quench
Calculated CR = 11.1:1
Cam:
Comp Xtreme solid street roller
298/304 at .015", 260/266 at .050", .627"(1.6)/.597" (1.5)
LSA 108, installed straight up
Lash spec = .016"
My Engine Analyzer Pro simulation program says this combination should crank 199 psi and will definitely be in the "detonation danger zone" running 93 octane.
My real world experience is that my 452 w/ 10.8:1 CR and a 298/298 at .020", 266/266 @ .050", 108 LSA solid flat-tappet cam installed on 106 ICL has been running OK on straight 93 octane. But the extra .3 in static compression AND the shorter cam duration could definitely change the dynamics of the situation. There's probably 15 psi difference in cranking pressure between the two.
Is my simulation program spouting bogus data in this situation? I don't place 100% faith in it, although it's given me valid data for trend analysis, etc., before. And if the cranking pressure estimate is accurate, does the rest of the combination still look "93 friendly" due to the chamber design, quench height, etc.?
Re: Is this combination 93-octane friendly??? [Re: BradH] #603779
02/04/10 04:43 PM
02/04/10 04:43 PM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
I have the same motor setup,If I stay off the cam(keep the rpms below 2500)it runs fine on 93 other wise I run 110 30% plus the 93.It's no fun driving around and you can't step on it without the detonation. Might be ok with a thicker hear gasket.
Re: Is this combination 93-octane friendly??? [Re: jvcuda] #603780
02/04/10 04:46 PM
02/04/10 04:46 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Re: Is this combination 93-octane friendly??? [Re: jvcuda] #603781
02/04/10 06:43 PM
02/04/10 06:43 PM
BradH Offline OP
BradH  Offline OP
I have the same motor setup...
How similar are you talking? Same heads / compression / cam... ???
Re: Is this combination 93-octane friendly??? [Re: BradH] #603782
02/04/10 06:56 PM
02/04/10 06:56 PM
UK
602heavy Offline
602heavy  Offline
UK
Maybe post up seat duration on both cams.
Re: Is this combination 93-octane friendly??? [Re: BradH] #603783
02/04/10 07:06 PM
02/04/10 07:06 PM
Aurora Colorado
BELVEDERE67 Offline
mopar addict
BELVEDERE67  Offline
mopar addict
Aurora Colorado
I have a 471 with higher compression (11.8) and nearly the same dimention flat tappet cam. I get no detonation. HOWEVER, I'm at altitude. That changes everything. So I would say you would be into the detonation area. Mix of gas will probably be needed. By design, it's very important to keep the quench in the .040 range. So a thicker head gasket will,imo, make it worse.
I'd build it and work with the timing to help to lessen the detonation effect. Mix the fuel and hold on.
Re: Is this combination 93-octane friendly??? [Re: BradH] #603784
02/04/10 07:22 PM
02/04/10 07:22 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
My challenger:
440/499 RB
4.375*4.150
Felpro 1009 (.039)
.052 quench
93 pump gas
Indy EZ heads MW cnc ported 2.19/1.81 ferrea
J&E Pistons
Comp XR286R solid roller 248/254 @ 50 on 110
11.12 to 1
never any issues and made my passes on pump gas...
I know you know this but you asked again.
Mopar Performance
Re: Is this combination 93-octane friendly??? [Re: BradH] #603785
02/05/10 10:08 AM
02/05/10 10:08 AM
NC
440Jim Offline
440Jim  Offline
NC
I am surprised you are considering less duration than you have now. In fact, I think the current one is conservative on duration. And 272ish would be more pump gas friendly.
Re: Is this combination 93-octane friendly??? [Re: BradH] #603786
02/05/10 02:18 PM
02/05/10 02:18 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I have a true 12.11 comp and crank in the 170`s w/275-280 @ .050 and drive everywhere on 91 calif junk however, I wouldn`t race this way and mix 110 when racing. Go bigger on the cam.......
Re: Is this combination 93-octane friendly??? [Re: BradH] #603787
02/05/10 05:52 PM
02/05/10 05:52 PM
Brad, please provide the cam timing events @ .050
Re: Is this combination 93-octane friendly??? #603788
02/06/10 12:31 AM
02/06/10 12:31 AM
BradH Offline OP
BradH  Offline OP
IO 22 BTDC
IC 58 ABDC
EO 61 BBDC
EX 25 ATDC
Re: Is this combination 93-octane friendly??? [Re: BradH] #603789
02/06/10 06:57 AM
02/06/10 06:57 AM
IO 22 BTDC
IC 58 ABDC
EO 61 BBDC
EX 25 ATDC
going by your supplied info, that's not going to be a 93 octane friendly combo above 26-2800 rpm. if all you want to do is putt around, you'll be fine, but if you want to really drive it and have no restrictions, some changes will be needed IMO. you can alway's retard the spark, but what's the point of killing the power? timing curve and air/fuel would need to be perfect to have any real chance of success.
Re: Is this combination 93-octane friendly??? #603790
02/06/10 07:48 AM
02/06/10 07:48 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Brad maybe this will help you some maybe not! But when i talked to Ray Barton Racing and my current junk is setup 11 to 1 and told them its mostly a pump gas street car they called bullet and here is the grind I got!
Bullet
269/269 @ 50
110*
in at 106
.430 lobe / .645 1.5's / .688 with 1.6 / .731 1.7's
IO 28.5
IC 60.5
EO 68.5
EC 20.5
.050 quench
4.500*4.250stroke 540
Mopar Performance
Re: Is this combination 93-octane friendly??? [Re: BradH] #603791
02/06/10 11:00 AM
02/06/10 11:00 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I think you'll be close. My CR is at 10.8. Cranking, it blows 185 psi on the gauge. IC (@ 0.050") is 60 ABDC.
