Manal Gear Box??? #603476
02/04/10 01:01 PM
02/04/10 01:01 PM
IOWA
rhanghian Offline OP
IOWA
I want to change out my Power Steering for Manual Steering. Any suggestions on where to go to get a manual steering box.
1973 A-body w/ 360ci.
Thanks Manal Gear Box???
Re: Manal Gear Box??? [Re: rhanghian] #603477
02/04/10 02:42 PM
02/04/10 02:42 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Just find you a good used unit, there basically all the same, any A body should work, take the pitman arm & coupler too, as for the steering shaft, unless its a calapsable shaft/column, you'll need a longer coupler to join the two, i cheated, all i did was weld my coupler too the manual coupler, this gave me the distance i needed, i wasn't going to give 130.00 for the aftermarket coupler, had a pro-welder do mine up for 20.00 bucks.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Manal Gear Box??? [Re: rhanghian] #603478
02/04/10 03:50 PM
02/04/10 03:50 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Did you know you can get a new one?
Flaming River is a sponser here and makes a brand new replacement box.
http://www.flamingriver.com/index.cfm/pa...prod/prd215.htm
Or you can go to one of their dealers and get one for a little cheaper.
http://www.summitracing.com/parts/FLA-FR1498/
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Manal Gear Box??? [Re: joedust451] #603479
02/04/10 05:09 PM
02/04/10 05:09 PM
On the early A bodies the inner steel shaft interchanges so I changed that in my 65 dart to the longer one for manual steering. Dont know if the 67/up A bodies are the same but somebody here will. On a used one move the pitman thru it's travel and see if it's smooth and how much free play the steering col shaft nub has (pitman centered:halfway thru it's travel range) and might take out the fill plug & see if it's not dry in there. I think the 73/up A bodys use a different pitman that on the centerlink end the taper points down (castellated nut on the bottom) whereas 72/earlier (to 67) the ball joint end points up iirc (I might have that backwards)so see what you need. Ehrenberg in MA recommended a combo of wheel bearing grease and gear oil melted together & thats what I used
Re: Manal Gear Box??? [Re: rhanghian] #603480
02/05/10 01:54 PM
02/05/10 01:54 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
IIRC in '73 the manual box got the bigger sector shaft (same as the power steering box) so you will need to get a '73-up box so that it will drop right in without changing any of the steering linkage.
Re: Manal Gear Box??? [Re: rhanghian] #603481
02/05/10 02:40 PM
02/05/10 02:40 PM
AndyF Offline
AndyF  Offline
The guys at Firm Feel can get you a manual box. There are a couple of different ratios available while you are at it.
