How'd the factory do it?? #603415
02/04/10 08:57 AM
02/04/10 08:57 AM
Elk Grove, Calif.
bigblock340power Offline OP
Elk Grove, Calif.
How'd the factory put in the dash along the assembly line? Were all the components in the dash along with the wiring before it was bolted in? I'm thinking yes on this one. I'm getting it all together now and I think I'm doing it this way.
Re: How'd the factory do it?? [Re: bigblock340power] #603416
02/04/10 09:33 AM
02/04/10 09:33 AM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
I don't know if the factory did it that way, but I've done it several times. It is the way to go. I recommend an extra set of hands for the install.
Re: How'd the factory do it?? [Re: B1arno] #603417
02/04/10 11:12 AM
02/04/10 11:12 AM
LENOX , MI
KMPX2 Offline
mopar addict
KMPX2  Offline
mopar addict
LENOX , MI
Yes it was all put in as one big piece
Re: How'd the factory do it?? [Re: KMPX2] #603418
02/04/10 11:20 AM
02/04/10 11:20 AM
n/w, PA
demonH1B Offline
demonH1B  Offline
n/w, PA
I'm thinking yes, too. The dash was assembled
in another part of the plant, that's why the
broadcast sheets were attached to the back
side of the dash, so the dash matched up
with the correct body it was built for.
Re: How'd the factory do it?? [Re: demonH1B] #603419
02/05/10 06:35 PM
02/05/10 06:35 PM
Elk Grove, Calif.
Elk Grove, Calif.
OK, you've all talked me into doing it the factory way. I thought that's the way it's done anyway.
