Trans fluid recommendations #603392
02/04/10 08:19 AM
02/04/10 08:19 AM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
Rebuilt 727,with shift kit, new turbo action tight 10", just good o'l dextron or something out there thats way better these days, heard that a quart of motor oil in the mix is a plus, is this true? Just a street car that goes to the track once in awhile. Thanks.
Re: Trans fluid recommendations [Re: Lew] #603393
02/04/10 09:37 AM
02/04/10 09:37 AM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
With that tight tc,dextron will be fine.nix the motor oil! But I would use the B&M trick shift tran fluid. Add a tran cooler if you don't have one already.
Re: Trans fluid recommendations [Re: jvcuda] #603394
02/04/10 09:45 AM
02/04/10 09:45 AM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
That B&M fluid ? ...decent stuff but big-bux. I would just use a Ford ATF.
An add-on trans cooler with a tight converter ? .... you can if you want .. but you could kill some of the stall-speed.
The radiator cooler/warmer should be enough.
Re: Trans fluid recommendations [Re: dOoC] #603395
02/04/10 10:34 AM
02/04/10 10:34 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
The Ford/B&M fluid should make for firmer shifts, but any fluid that is made for a torque converter clutch should be good too.
Since my garage does not have any Ford vehicles, I'm planning on running ATF+4 in the fresh 727 in the van (same as the truck and the 518 in the 40). Less stocking.
