Car's running hot... What should I change?
#60321
05/20/08 02:41 PM
05/20/08 02:41 PM
Posts: 265 Garland, Texas
1badmopar
Garland, Texas
I constantly struggle to keep my engine cool. I have tried everything, but cannot seem to find the right combo. What should I try next? I am so frustrated that the money is not an object.
Currently, I have a 19x31 aluminum radiator, dual 12" Permacool fans, Meizer 35 GPM water pump, and a 160 thermo. The car idles at 180-185, drives at 180, and then will heat to 200-220 sitting at stop light or in traffic.
The motor is a "520 RB with Eddy heads and 10.5:1 comp. I am even running the low friction 1/16 3/16 rings. It is a big motor, but not radical.
Do you think the block could be stopped up?
1966 Plymouth Belvedere 520" RB w/ Indy 440-1 Heads FiTech Fuel Injection TKO 600 conversion [img] https://flic.kr/p/2j1ejsK[/img]
Re: Car's running hot... What should I change?
[Re: 1badmopar]
#60323
05/20/08 03:01 PM
05/20/08 03:01 PM
Posts: 4,848 Memphis
HemiRick
Memphis
The fact that it only heats up when cars not moving tells me it's lack of air flow.....Those electric fans just aren't cuttin it.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: Mr.Yuck]
#60324
05/20/08 03:11 PM
05/20/08 03:11 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
the fans might not be big enough. on my big block, I had a 10" fan and a 14" fan on my radiator, together, they did not move enough air to keep me cool. I went with an OEM 19" fan that moves so much air, the plastic blades actually suck in towards the core about 1/4" and it pulls 30 amps or more at start up. maybe 10-15 once it's running
that fan with a shroud, is enough to keep me cool now.
**Photobucket sucks**
[Re: HemiRick]
#60325
05/20/08 05:00 PM
05/20/08 05:00 PM
Posts: 989 WI, USA
67dodge67
mopar addict
mopar addict
WI, USA
I had a similar problem with my 470 not too long ago. The fan I had was not doing the job. I ended up swapping out the "flexi-lite" or whatever it was called for a bb mopar clutch-type fan set up. That thing draws a TON of cool air thru the radiator when sitting in park or traffic it's rediculous.
[Re: 1badmopar]
#60329
05/20/08 08:42 PM
05/20/08 08:42 PM
i had that same problem with my 440 until i put a 7 blade fan and a shroud on it runs cool now
